Question about Samsung Televison & Video
Makes terrible wurring noise and picture becomes distorted
  • Samsung Master
  • 8,617 Answers
Your color wheel is the most likely cause of the noise, the bearings are prone to failure, second in line would bee the cooling fan.
Posted on Jul 06, 2008
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Clicking noise stihl 250
Probably your clutch is loose and noise is coming from chain cover. Anchor the bar in a vice and remove the nuts holding the cover on.
Mar 05, 2014 | Garden
My 412Hot Rod Deville has terrible humming/white noise when distortion channel is on
It doesn't happen often but I suspect that the high gain input jack is defective. With nothing plugged into either input jack part of the signal is grounded and there should not be any noise. It might be that plus a noisy preamp tube. Try swapping the first two tubes to see if there is less noise. Carefully bang your fist or use an insulated tool's handle to hear if the noise changes. It might be an intermittent solder connection as well.
Jul 15, 2017 | Fender Hot Rod Deluxe Guitar Combo...
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Car is makin a wurring noise as it gets faster
It Makes Noise As like As Speed Increase, Check Wheel Bearings. Thanks.
Jan 14, 2010 | 2009 Mini Cooper
Aqualisa Aquastream shower noise from pump/motor ?
aquastuream loud noise?motor/pump
Mar 30, 2009 | Home
GE D52GW12, picture is distorted and snaps
its either the HV splitter or the flyback which needs replacement. You can get both items at the following link with free instructions.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Aug 25, 2006 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
70 people viewed this question
Jerry Greenberg
Jerry Greenberg
