Floppy disks are formatted but when inserted it tells me it isn't formatted and I cannot format then because all the information will be lost. Can you help?
  • 19,396 Answers
This often happens when the Floppy Disk drive head is faulty or out of azimuth. Usually when this happens you need to replace the froppy disk drive unit, which is not an expensive part.
If you do not want to take apart your PC to change the internal FDD, you can also buy an external USB floppy drive, in this case ensure you have a free USB port on your computer.
Here is USB external FDD:
External Floppy Disk Drive - Black
Here is internal one:
1.44MB Floppy Disk Drive
Posted on Jul 06, 2008
How to Create a Startup Floppy Disk?
Insert a floppy disk into your computer's floppy drive. Open My
Computer, and then click the floppy disk drive to select it. On the
File menu, point to the name of the floppy drive, and then click
Format. Under Format options, click Create an MS-DOS startup
disk .
Oct 19, 2016 | Computers & Internet
Designer 1 Embroidery - how to download designs from internet and transfer to floppy disk
In addition to checking your floppy disc, you might check and see if it uses VIP format, I have a Designer II and it uses both!
Nov 13, 2013 | Husqvarna Viking Designer 1 Embroidery Arm...
When i try to run a disk it says the disk is not formatted do i want to format it now. the disk has information on it so it has to be formatted .
It is possible that there are errors on the floppy disk or the disk was formated using a format that is incompatible with the current operating system. If the disk is readable on another system, the best solution would be to copy the files onto a portable USB flash drive, then reformat the floppy disk using a filesystem that is readable on the desired computer.
Apr 22, 2011 | SmartDisk USB Floppy Drive Titanium...
Absolutely EVERY floppy disk inserted tells me that the disk is NOT FORMATTED. I know for a fact that there are files on them.
I suspect a problem with either your former drive or the TECC drive. May I suggest you try formatting a disk with the TECC to see it will recognize that disk as formatted?
If your other drive was a little off and all your floppies were written by that drive, I hope you still have it. On the other hand, if the floppies were written by the TECC, it being a external drive, it may have been dropped accidently and it now is out of whack requiring adjustment.
Im sorry you are having this trouble.
Dec 05, 2010 | BYTECC (BT144) External Floppy Drive
Computer will not read floppy disk
You have a bad floppy drive. In this system you almost have to gut it to replace the floppy drive, although used floppy drives should be pretty cheap on eBay. If this is a one-time thing, a USB floppy drive should do the job just as well.
Feb 14, 2010 | Toshiba Satellite 2805-S202 Notebook
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
My floppy drive tells me to insert a disk when I try to use it
Sounds like you have a bad drive or the disk is corrupted. Did you try a different floppy disk to see if the drive is functioning?
Mar 21, 2009 | Computers & Internet
I am trying to transfer photos and data from 3.5 disk to cd's and memory cards but when I insert a disk it is telling me that the disk is not formatted and ask me if I want to format now. I know these disk...
You can't retrieve data from those disks on whatever computer you're using it on. It apparently doesn't support the same format that you used save the data to the disks initially. I don't know what you can do, other than just trying the disks on any computer you can find that has a floppy disk drive until something works. Personally, I absolutely hate all the formats there are for removable disks. I have problems just like that with CDs all the time.
Well, good luck.
Feb 02, 2009 | Mad Dog Multimedia Dominator (MDED1F)...
Asking to format not reading floppies
I can tell you just what I told someone else with the same problem a minute ago. Your computer doesn't support the floppy format you saved the data on the disk with. All you can really do is try putting the disk in every computer you can find until one of them reads it. So, basically, there may not be much you can do. Personally, I hate removable disks. I have that same problem with CDs all the time.
Well, good luck.
Jan 08, 2009 | Mitsumi (11-08004) (1108004) External...
NOT FORMATTED
The error means 3 things:
1. Files format of the files saved on the Floppy disk is not readable on the OS or does not comply with the file format of the OS. So you really need to format it.
2. The floppy disk is brand new and you need to format it first.
3. The floppy disk is not working. Try a known working floppy disk.
Oct 12, 2008 | NexxTech USB External Floppy Drive (NEFD2)...
Computers & Internet Logo
David Payne
David Payne
