Question about HP PSC 2210 All-In-One InkJet Printer
Aligning cartridges My printer after changing a new cartridge keeps on aligning and doesn't copy which Iam desperately trying to do pl help
  • 1 more comment
  • Anonymous Jul 16, 2008
    impossible to aline cartrige
    it s the same problem
  • Anonymous Jul 25, 2008
    I am having the same problem. I can't copy anything. It just keeps saying to press enter to align cartridges which I have done at least 10 times. However, I can print something I have saved on my computer. Help.
  • 61 Answers
First ckeck out your cartager are ok if your cartager are ok then when the align page print it will scan and once the align page is detected , align page printing will be stop.
Posted on Jul 24, 2008
The Lexmark x5495 printer is not printing correctly. The printout is not aligned properly. The printout is crooked. How can you solve this problem?
Try to re-seat your cartridges and make sure they are properly inserted in the cartridge carrier.
If that doesn't help, please do the Align Cartridges function on your printer. From the printer operator panel, while on Copy mode, press the Menu button > Tools > Maintenance > Align Cartridges. You printer will then print a test page that will help align the cartridges.
After the page is printed, try to print a document again to verify that the problem is fixed. Thanks.
Feb 25, 2012 | Lexmark X5495 Printer
Printer spits out blank copies. Says there is an alignment problem but I cannot find how to fix it. PLEASE HELP!
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please follow the steps below to align the cartridges:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 7100 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and help align the cartridges.
Oct 05, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have try to print but its not printing. i've allready fill the ink still the page come out blank.
It could be due to the refilled cartridge that you are using. Refilled cartridges tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. Please follow the steps below to fix the problem:
  1. On the printer control panel, press Copy.
  2. Press Options until Maintenance is highlighted.
  3. Press the right arrow until Align Cartridges or Clean Cartridges appears, and then press Select. A test page will then be printed forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the cartridges are working.
If that doesn't help, I would suggest you replace your cartridges with new genuine Lexmark cartridges.
Aug 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
I put in a new cartridge (56) and now my alingment
after replacing the cairtage printer needs alignment it gives a test page when we put it face down on scannes it starts the alignment...
on alignment process it doesn;t found the colour bands so it shows the alignment failure..........
pls install the new colour cairtge the it will give u the printout
thanks....
Jul 08, 2010 | HP PSC 2210 All-In-One InkJet Printer
My HP Officejet 4315 states Cartridge Error. Can
HP F2480
Align Cartridge:
If you have just installed a new cartridge it is recommended that you align it. Click on "Align" to align your new cartridge
Dec 09, 2009 | HP Officejet 4315 All-in-One Printer
Lexmark X-4270 all in one won't copy
try cleaning the heads with the fix on the printer help screen.go to-- help--type in printer copier won't copy- look for how to clean the heads of the ink pores. or try align cartridges. when you install new printe ink or the cartridges come with the machine you have to aline to keep the ink flowing right.
Oct 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Incorrect right cartridge
Ive tried removing the right cartridge so I can print in black, but now , once I refilled the black one, it wont even let me print black!! this is desperate; can anyone help?
Aug 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
95 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
