Question about Gateway Computers & Internet
Computer laptop problem
Can only pull up computer in safe mode. After trying a recovery it tells me that the windows firewall did not load. After a couple of times of trying to bring it up, it will allow me to bring it up in safe mode.
  • 3,940 Answers
Generally, when a firewall or antivirus application fails to load, a virus is the suspect cause. Many viruses are designed to attack/disable the firewall/antivirus as to infect the system. If the operating system has beenn compromised to the point you can only boot in the safe mode, the likelyhood of removing the viruses and still being able to repair the operating system WITHOUT a clean reinstall of Windows is not great.
Things you can try.
  1. If you have more than one computer, see if you can connect this drive to a healthy system, and remove the infection.
  2. Run hardware diagnostics on the hard drive, as a hardware failure can mimic a software problem by files being damaged writing them to bad sectors of the media.
  3. If you can access the internet in safe mode with networking, or can access internet with another system, you can download several programs/tools to try to remove any infections. www.gur,in is one page with a large assortmant of tools to try to use to remove any infection. Sometimes you can install and run these in the safe mode or use safemsi.exe to enable some installers to run in the safe mode.
If the hard drive fails diagnostics then you will have to replace the hard drive. If it passes diagnostics, and attempts to remove infection fail, boot to XP cd, format the hard drive and do a clean install of windows the reinstall all drivers and applicaitons. If the format fails, replace the hard drive
Posted on Jul 06, 2008
Blue screen when windows loading screen
There's a number of reasons that you could have that issue. HDD failure, RAM failure, some sort of Windows driver issue.
Try restarting the computer and before the Windows loading screen, start mashing the F8 key. That should bring you to a screen that offers to start you in safe mode. Try starting in safe mode, which only loads the absolutely necessary files for Windows to load, and see if it'll start up there. If it does, attempt to use Windows Recovery Tool.
Mar 03, 2015 | Acer Aspire Computers & Internet
When you turn on the lap top it says operating system not found. I put recovery disk 1/3 in and it loads windows files. Then a screen pops up and says windows recovery center or repair windows. For more...
Do not press on F8. What you need to do is to do a start up repair. Select the option to repair the operating system. Then it will load some files. JUst wait for it to complete the loading process or the repair. It will tell if the repair is successful or not. If it doesn't fix the problem, then, you need to install the operating system to your computer. But, remember that operating system re-installation will return your computer to scratch. It will erase everything including the files and programs that you have added in your computer. But, if you don't have anything to lose then do the operating system reisntallation.
Here's a guide on how to reinstall windows vista:
http://www.blackviper.com/Articles/OS/InstallVista/installvista1.htm
Mar 22, 2011 | Sony Computers & Internet
My computer crashed and it won't boot up. i don't have a recovery disc, is there anyway to load it back up without taking it to someone?
You can press F8 during the POST to get the SAFE MODE option and try and go into safe mode and see if you can do a system restore while in safe mode.
Nov 06, 2009 | Toshiba Satellite A215-S4747 Notebook
Lap top computer
Sounds to me like a windows problem or maybe a driver error. if it boots up in safe mode and it dont boot up in regular mode, one of the drivers that dont have to load in safe mode keeps crashing it. check all startup programs and disable as many as you can
Oct 18, 2009 | Computers & Internet
Blue screen on my laptop, not able to load another window
reinstall windows - run your recovery disks, or boot from the recovery partition. If it still happens, there's probably a hardware issue - could be anything. Call Toshiba if still under warranty...
May 15, 2009 | Intel Computers & Internet
Won't load windows
Try pressing F8 on startup to start the computer in safe mode.
If it does not restart in safe mode, then you need to reinstall Windows using the recovery CD or a Windows setup disk.
If you do not format the hard drive , and do a windows upgrade setup on top of same system folder, you will preserve your data.
Apr 28, 2009 | Dell Inspiron E1505 Notebook
Acer aspire 5100 will not run windows. It say's ''starting windows'' and then freezes. The recovery cd will not load. I'm able to load and run windows 98, but nothing newer. Thank you
ok
sir when upower up the computer press F8 key then u see safer mode if u are able enter in safe mode.
then u not need winxp recovery disk.
After enter in safe mode.
Go to satrt menyu then run then type in run "chkdsk /r" then press enter then press "y"
then restart the computer .
Also change the screeen resolution to 1024*768
some tiomes it is disaply resolution problerm.
So alos try "enable vga mode " u can see it when u power up the computer and press F8 key .
Try both my suggestion sir.
Thanks.
Apr 22, 2009 | Acer Aspire 5100 Notebook
I can not get my Acer Aspire 5920 to load after turning on.
Try to see if it will boot in safe mode, by pressing F8 while the laptop boots up. If it allows you to boot in safe mode, try to do a system restore when you know that laptop was working with no problems. You can do this by clicking on start>all programs>accessories>system tools>system restore and choose a date and time when you know that the laptop was working with no problems. If this does not work or you cannot boot in safe mode (be aware that everything will look big in safe mode and when the computer reboots if asked how you want to start windows, choose start windows normally), try doing a recovery. This will restore your computer to the factory default settings when you purchased it. You can do this by booting the computer, when the acer screen appears hold down the ALT key and continuously press F10, this will open the recovery manager and you can restore it from there.
I hope this helps
Jan 20, 2009 | Acer Aspire 5920-6727 Notebook
Cannot start up laptop; may be a virus
Try starting your computer in safe mode and do a virus scan once in safe mode. While in safe mode Windows only loads the basic devices to run your computer and usually viruses are not loaded untill windows starts in regular mode. Don't panic once you are in safe mode and your screen looks all grainy, this is normal.
  1. Restart your computer and press F8 as soon as you turn it on.
  2. Click the "safe mode with networking" option
  3. Update your antivirus
  4. Do a full system scan
  5. Restart your computer and hope for the best.
Jan 05, 2009 | Balance CN6555 Notebook
Can you help? Have a Advent 7096 laptop protected by PC Angel. Have run system recovery using 4 discs. Cannot get into Windows - message reads "load needed dll's for kernel" Not my machine but...
If you having problem running system recovery in normal mode try running system recovery in Safe Mode by pressing F8 key when you turn on the laptop.. a selection pop-up, select your primary hard disk where your windows installed still pressing F8 then a Boot Selection appear select Safe Mode after starting in Safe mode do the system recovery.. still not working choice the Last Good Configuration. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
Computers & Internet Logo
259 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
