Question about KitchenAid Dishwashers
We need to replace the little rubber latch that keeps the dispenser door closed on our Kitchenaid dishwasher. Do we need to replace the whole detergent dispencing unit or just the latch. And if we do have to replace the whole thing, do you know how it attaches and have advice for that repair? Type is Kitchenaid KUDS01IJ
  • lori55 Jul 12, 2008
    I called Kitchenaid because I couldn't find just the actual latch anywhere to purchase. They told me that I have to replace the whole detergent dispenser unit and the individual latch isn't available for purchase.
  • KitchenAid Master
  • 19,396 Answers
Posted on Jul 06, 2008
    Master:
  • 726 Answers
I searched it up and you only have to change the actuall latch
MY SOAP DOOR WONT STAY CLOSED
Soap dispenser latch problem.
a) Look at the latch whether there is build up of soap. CAREFULLY clean it. It might work.
b) If not just replace the whole dispenser unit. Not worth wasting time on trying to fix the spring problem. Most dispensers are $ 50 ~ $ 100 price range.
Sep 26, 2014 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Kitchenaid dishwasher KUDS30IXBL door locked open, will not close
There should be a type of hook inside the hole where the door latches to the machine. Hold the handle up and rotate the hook latch so the open side is pointing towards the machine. The click you heard was the latch that holds the door closed moving to the closed position when the door was open, and it needs to be in the release position.
Jan 28, 2013 | KitchenAid KUDS30IXBL Builtin Dishwasher
The dishwasher door keeps popping open mid cycle and door will usually not close or stay closed. it takes 4 hours of me hitting continue and holding the door closed to get it to finish a load
The catch on the door latch assambly is weak and the latch needs to be replaced, this vidoe will show you how to replace the latch,the part# is 8183830 it could be purchased at your local appliance parts store or online at,searspartsdirect.com assuredaprts.com apdepot.com
repairclinic.com appliancepartspros.com
Aug 08, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
The latch on my kitchenaid dishwasher is loose or broken and I can't open the door. Any ideas. Model #KUDS24SE
yes remove the top of machine and make sure the power is switcht off.;;;;;on the front of machine with your hand pushed down to the door switch ,not easy but keep trying,you will find the door switch with both hands wrigle until the door opens i know its hard and your hand will suffer but it will open keep trying,this switch needs replaced at all costs,you might have to replace the switch plus the holder .Once door is open unscrew the two screws and the whole latch will be in your hands remove the plug and you will have it in your hand ,replace backwards to what ive said,good luck psthis part/sshould cost 20 dollers.
Dec 04, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
I need to replace the detergent dispenser latch on
To replace the parts you have to buy a whole dispenser assemble for $100 to $200. To buy some time ... Get a heavy gage sewing needle - hold it with pliers and heat it red hot. Stick the hot end into the plastic door at the area where the plastic latch is (where it will line up with the far end of the latch mechanism). when it cools cut off most of the needle leaving one eight to one sixteenth (more or less) protruding. Use a drill and small bit to remove some plastic (or drill a small hole) on the spring latch mechanism. push the remaining part of the needle in or out to engage the hole in the latch.. this will hold awhile.
Jul 19, 2010 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
Removing the detergent dispenser
I have the same problem--mine is about 10 years old. To disassemble, looks like you will need to disassemble the complete door--screws around the inside edge of the door. At that price for a replacement dispenser, I will either try to fix or replace the blue arm, or replace the dishwasher. I don't believe its worth putting that kind of money in an old dishwasher.
Lew
Dec 10, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
213 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
