Question about Microwave Ovens
Microwave Panasonic Slimline Combi Door release button does not release door and  door hinge has recently started binding can you advise what to do Thank you
    Sergeant:
    Champion:
  • 417 Answers
Sounds Like A Part That Releases The Door Has Slipped Outta Its Place were the button is located
Posted on Jul 06, 2008
Door came off. Can it be repaired?
perhaps someone that welds could fix it . should have done something a year ago
Jun 11, 2015 | Panasonic NN-SD797S Microwave Oven
Door release button does not work
busted plastic part in microwave send model # we can find the part you need
Feb 20, 2015 | Panasonic NN-SD277WR - NN-SD277WR...
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
I HAVE A PANASONIC NN-CT776 COMBI MICROWAVE AND THE DOOR REFUSES TO SHUT ANY HELP PLEASE?
Failure of the lock mechanism , fault in the lock switch which cuts off the power to the microwave when the door is opened or a fault in the hinges.
Remove the top cover and look on the sides to the lock section, It is possible that the switch has closed not allowing the door lock to latch. You can use a screw driver to push this and press the door to reset.
Please have the power supply removed.
Jul 23, 2011 | Microwave Ovens
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
Broken door catch, possible spring, Panasonic Slimline Combi microwave oven NN-A554W.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Nov 26, 2008 | Microwave Ovens
I purchased a Panasonic NN-AW554W Combi Microwave from Amazon on 18/09/2007. On 15/9/2008 I started the microwave and it immediately stopped working and tripped the circuit breaker in the fuse box. I...
Something about that model number doesn't look right. It's not showing up...
Since it failed just inside the warranty period, I would waste no time in contacting Panasonic to verify the warranty and find an authorized service center to fix it free.
You can find their contact info in your owner's manual or reply back with what country you're in and i can give you a link.
Otherwise, please visit this site and pick out your country, then look for the Support link.
I would say you have an issue with a bad door switch or misalignment of the door switch holder or hinge.
Sep 19, 2008 | Panasonic Microwave Ovens
Broken Door Catch Now oven won't work
You can order parts online by entering your full model number (without dashes) here: http://www.pasc.panasonic.com/epartr Chances are the panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices. If you still have questions, please feel free to follow up. I appreciate your thoughtful ratings to my reply.
Aug 29, 2007 | Panasonic NN-V671S Convection Microwave...
Microwave Ovens Logo
527 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
