Question about Gateway 2520915 Keyboard
Computer keyboard. I have problem with the computer keyboard. When I press shift key and press 2 for at the rate sign the inverted commas appear and vice versa. I changed the keyboard but the problem persists. I have samsung keyboard now.
  • 2 more comments
  • salawatkunal Dec 08, 2008
  • milnedanny Dec 23, 2008
    Every `time I `hit `the `space `bar `a `little `dash `appears, `as `you `can `see `here! `Could `someone `provide `a `fix `for `me? `Thanks.
  • Anonymous Mar 08, 2009
    I have the same problem but instead of the inverted commas when pressing 2, when I hit shift and then try and throw in a question mark, I get é instead, so whenever I type in a question, instead of a question mark I get "é" instead. I have tried going to the control panel but keyboards options doesn't exist there for me. Help me out please, Thanks.
  • salawatkunal May 11, 2010
    have problem with the laptop keyboard. When I press shift key and press 2 for at the rate sign the inverted commas appear and vice versa. I
    President:
  • Gateway Master
  • 1,314 Answers
The problem does not lie in your keyboard, but rather the keyboard layout settings. Go to control panel, keyboard options and select the standard US settings.
Posted on Jul 06, 2008
Go to control panel---regional and language options---languages---details---settings---default input language---select US International and use the same for installed services.
Posted on Jul 31, 2009
How to use the @ sign on Logitech keyboard K480 Tried using the shift key but only get the option of inverted commas or apostrophe
You will need to set the correct keyboard on the PC. Alternativly try shift and the number 2 (on the top row of keys NOT the number pad)
Sep 05, 2016 | Logitech Bluetooth Multi-Device Keyboard...
When I type I don't get the inverted comma as it gives me the "at " as in "@" and vice versa. Also the back slash key gives me hush instead and the shift-3 which is supposed to give me...
Be sure that your keyboard is configured properly. You should be able to check under the "Region and Language" area of control panel if you are in windows and select "Keyboards and Languages." Check that it is set as a US keyboard or that it's set to which keyboard type you are using.
May 02, 2011 | Toshiba 310CDT Keyboard
My Acer key board can not display the at sign above TWO key shows inverted commas instead and the hash sign above THREE shows a Pound sign? Please assist
Hold down the ALT(ernate) GR(aphic) key -- to the right of the SPACE BAR on your keyboard.
Press the '2' key.
Release the '2' key.
Release the ALT GR key.
Does an '@' display?
Check that you are using the "American English" keyboard mapping.
Control Panel -> Regional options.
Mar 06, 2011 | Acer NSK8458AN Keyboard
ViewMate Keyboard: when I press shift 2 I get inverted comma. donot w...
you need to change the keyboard lay out install US if the machine is from US and UK if bought in the UK goto regional settings etc
May 16, 2010 | ViewSonic ViewMate Keyboard
When i press the shift, inverted comma key, I get "" (two sets of inverted commas). When I press the apolstrophe key I get nothing. If I press it twice I get '' Help!
Go to control panel and check the regional and language settings. make sure it all says English and/or United States, if you are in the states that is, otherwise the keyboard will be different.
Oct 14, 2009 | Computers & Internet
Problem of keyboard keys getting transposed.
Your region and language settings are incorrect.
Go to control palel/Regional&Language settings/ use the drop down menu to select the correct region then click on languages tab/details and do the samme. apply and exit.
Sep 23, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Two keyboard keys seem to have been transposed
Yes when going through the setting up procedure for your new computer you should have installed the British keyboard instead of the US one.
Doing the above will correct your problem.
Nov 09, 2008 | Computers & Internet
I have an Advent wireless keyboard problem
Your keyboard is probably set to the wrong region.
Start, control panel,Regional and language options,languages,details.
select united kingdom keyboard and delete the usa one.
this is right for XP - If your using Vista it might be different.
Also I bet the @ key will give you a " sign so this could be a temporary fix
Feb 28, 2008 | Computers & Internet
@ key
This is a problem I had at onre time and it turned out that I had selected the USA Keyboard in stead of tthe UK Keyboard, you could have the same error or vice versa (ie Uk instaed of USA) so go to START then select CONTROL PANEL then select KEYBOARD and check which is selected and correct if necessary.
All The Best
Jan 02, 2008 | Acer NSK8458AN Keyboard
Gateway 2520915 Keyboard Logo
740 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
