Question about Zanussi FJS1225W Front Load Washer
Softner wont go into the washing machine
Hi
can you help the softner wont go into the washing machine it just stays in the drawer, any ideas how to fix this.
I have cleaned the softner tray.
The water jets above the tray had black residue in them. How do I remove the front plate so that I can clean the jet holes more thouroughly?
thankyou.
  • dalemk Aug 31, 2008
    is this the same foe zanussi f1256 w... jets are badly blocked and it really doesn't look easy to remove unit above dispenser. have tried unblocking as you suggested above but it doesn't work...just pushes gunk up. i am an engineer (not washing machines) so if you have some directions i would like to have a go!! thanks Dale
    dalespost@yahoo.co.uk
    Problem Solver:
  • 10 Answers
Removing the front plate won't help you, take the draw out. Get a long bag tie or inner core of any mains twin and earth cable and push it into the holes in the top of the dispensor, move it about in/out etc, changing the holes as required, this normally works, if it doesn't the dispensor lid is available as a seperate part and is quite easy to change.
Posted on Jul 18, 2008
Softner not being flushed into machine
Hiya,
there is only a few reasons for the softener not to filter through firstly i would surgest removing the drawer that the softner goes in & flushing it through with hot water this will help dislodge anything that may have built up inside, sometimes the fabric softner section has a top part that comes off if so remove this & flush both sections, if you can see a black sludge then it is just build up that is blocking the path stopping the softner getting through.
Hope this helps
Apr 21, 2010 | Bosch WBB24759GB Front Load Washer
My servis washing machine wont take in softner
Try a "good quality" name brand liquid softener. Some softeners out there are real thick and settle out to be paste. This problem was encountered by me and since I changed to a real liquid, it went away.
Oct 24, 2009 | Washing Machines
FABRIC SOFTNER TRAY STAYS FULL AND IS NOT RINSEING OUT
HiYa dh1200s
The softener tray needs to be cleaned out or the sensor for this replaced.
Yes, not enough water entering machine so not enough water to rinse out the softner
Please leave a good rating before you sign off.
Mar 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
Fabric softener not dispensing
Fabric softner trays often clog up, because a little soap powder in the tray by accident tends to block it. If you pull the soap tray out as far as it will go, you will see that there is a bit of the tray right at the back, probably on the left with an arrow or thumb print or indentation in it. If you press down on this it is a catch and it will allow you to remove the tray from the machine completely. Once out of the machine, the fabric softner cover will also lift out. Clean everything throroughly (Tak it outside and turn your garden hose full pressure on all the holes on the tray and then scrub it out with a toothbrush. Put the fabric softner tray mabc in and slide the soap tray back in the machine. This should have fixed it.
Mar 01, 2009 | Whirlpool Washing Machines
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Eco Care Front load washer:Fabric softner clog
pull drawer out press down on tab rear left side and slide drawer out
Jun 04, 2008 | Kenmore 44832 Front Load Washer
Zanussi jetsytem fjs1225w
clean the draw out remove the top where the softner goes and clean under there.
Jan 22, 2008 | Zanussi FJS1225W Front Load Washer
Machine wont take conditioner
hi there remove soap drawer and softner compartment lid clean throghly both hole and tube inside and out failing that clean soap box lid inbside with bottle brush at worst you may need to replace the soap box lid assy
hope this is of some help
Jan 11, 2008 | Zanussi FJS1225W Front Load Washer
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
138 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
