Question about Zanussi Washing Machines
How do you fit a drain hose to a zanussi WJD 1257 W
    President:
  • 1,462 Answers
Tilt machine backwards at a good angle.look underneath and you will see that the drain hose is connected direct to the pump and held with a spring clip. just undo with pliers and bobs your uncle
Posted on Jul 06, 2008
Dryer with no heat
It sounds like an intermitent Thermostat problem.
Sep 02, 2007 | Zanussi WJD1257W Front Load Washer
Zanussi tumble dryer zdc37202w where does the hose fit as i want the water to go into siphon and not the condensate tank.
Unfortunately, nowhere in the user manual does not described how the connecting hose to drain water into the siphon.
Dado
Feb 18, 2015 | Zanussi Dryers
Electrolux troubleshooting
Very hot says heater is okay perhaps the fan is not operating due to cut out.... this fan blows air which is then heated and dries the clothes,if its a condenser drier then check also the water valve is opening and pump operating...
Nov 01, 2013 | Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
WJD 1257 works fine but After 1&1/2hrs knocks of the main power fuse even if only on standby. I remove plug, put fuse switch back and all is well until the next time. Have tried the other socket but no...
Try to see the capacitor of your the machine. The capacitor looks like a circle tube of plastic ware where the 4 wires are connected to it. it is only for the washing machine with the dryer. If it's only a washing machine the, the capacitor is only a single or only two wires are only connected. To test if that is the common problem, try to connect another functioning capacitor.
Mar 11, 2011 | Zanussi Washing Machines
Iv got e90 and e91 coming up on my 1200 wjd 1257 w can you help me rob
E90 - communication error between printed circuit boards. check connections.
Nov 01, 2009 | Zanussi WJD1257W Front Load Washer
Grey sludge on my washing
Hi, I had the same problem.
The waste is blocked, check the drain pipe from the machine and also where it drains out to. (thick sludge)
I ended up unclipping the pipe from the drain motor (Bottom rear) and passing a garden hose throught it to flush it out.
Jan 07, 2009 | Zanussi FJ1254W Front Load Washer
Washing Machines Logo
184 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
