Hi, Have just purchased Samsung DVD HDD recorder (DVD-SH855). Everything works great except the timer recording. When i schedule a recording, the system wont start recording. The recording light flashes at the scheduled start time. Instructions say check the date & time or the disk is full. I've double checked the date and disk has 421hours of recording left. Any suggestions?
I had the same issue. It turns out that the recorder has to be switched off otherwise it won't record. The unit will power itself on at the scheduled time and record your program. It doesn't make any sense to me why this would be a requirement but it solved the problem for me.
Posted on Jul 25, 2008
DVR will not record to hard drive
I did a (General Settings) RESET. Then I erased all programs on the HDD. Presto - it now records to the HDD a-ok.
Dec 19, 2011 | Philips DVDR3575H/37
Samsung dvd sh855 unable to record tv to 250gb hd using timer settings: however can record to the hd using instant record button.
is there any error message or can you provide some other info why you can't record..?
Thank you
Apr 30, 2008 | Televison & Video
Samsung DVD-SH855
Hi Thanks to all. Problem was solved by my son who suggested that I turn the unit off in standby mode. Samsung DVD-SH855 will not record via timer settings when the unit is left with pwr on. Only works if pwr switched off.
Had I known this prior to purchasing I would have purchased a brand that worked with pwr on.
See:
http://www.avforums.com/forums/archive/index.php/t-617483.html
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Apr 20, 2008 | Samsung DVD-HR720 DVD Recorder
Samsung DVD SH853M Freeview/HDD/DVR. Recorded list - cannot access
The Manual fro this machine is typically vague on the minutae of setting up and performing various functions.
Apparantly the 'standby button' on the handset should be in the 'off' position not the 'on'.
The logic of the layman can seee it as the opposite. This does work..... and thank you for your patience.
Mar 18, 2008 | Samsung Televison & Video
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Programmed recording to the hard drive
Either You haven't set the time/timer correctly or you need to find a way to clear/format the hard disk.
Aug 16, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Jul 03, 2007 | LG DBRH197H DVD Player/HDD Recorder
Televison & Video Logo
198 people viewed this question
Top Televison & Video Experts
