Question about Brother MFC-665CW All-In-One InkJet Printer
Brother MFC 665CW - Not connecting with XP
I have the printer set up on a wireless network. It connects to two laptops and a desktop with Vista but I can't get it to link up to the laptop with XP.
I've tried installing as instructed but it can't find it and when I try to go through the "Add Printer" printer -> Add Network Printer and it can't find it on the network...
Any help would be great. Thanks.
  • TonyB52 Aug 01, 2008
    I started to print labels in Word and nothing. I can almost reinstall from the disc..but it stops near the end and will not complete the installation.
    The printer will copy and scan but will have nothing to do with the computer. Everything is connected properly as far as I can tell.
    I am at a loss to fix the problem..I usually can remedy problems by reading...the manual does not help.. Tony.
I've tried everything including several driver utilities on Brother's own website. I even tried copying all the driver files identified in the device manager on an xp computer that will print to it. My last resort is to download the entire 80mb full software & drivers from Brother. I assume that's how I got it running on the other laptop years ago (but from the original disk that I can't find now). If you don't know where this is, google "mfc-665cw xp drivers" & you'll see a couple links to the Brother website. Click any of them, select "downloads" at the top, then at the left, under "notes," find "click here to see all downloads for this model. Scroll down through OS's until you get to XP & you'll see what I'm talking about. Good luck.
Posted on Jul 08, 2008
My brother mfc 665-cw is saying offline no matter what I do to try to print wirelessly
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Apr 25, 2011 | Brother MFC-665CW All-In-One InkJet...
Brother MFC 665CW can no longer scan since networked
That's rather normal, if your printer doesn't have scan-to-email functionality, you won't be able to scan unless you connect it via USB to a selected machine.
Nov 20, 2009 | Brother Multi-Function Center MFC-665CW...
Brother MFC-9840CDW Wireless printing on Vista
maybe is not configured to work with vista;s sorry.
Mar 19, 2009 | Brother MFC-9840CDW Laser Printer
Share printer
First you have to set up a home network between both your computers, once that is established run an networking cable to your printer it should all be ran through a networking hub so all machines can communicate with one another
Jul 05, 2008 | Brother MultiFunction Center MFC-440CN...
Printer only runs with usb,
If you're trying to run your USB printer over a wireless connection, a USB device server like the Silex SX2000U2 will connect to your USB printer, then provide a wired network connection that you can connect to your wireless access point. Belkin also has a "USB Network Hub" that does the same.
This will make the printer available on your network and you can print to it from another computer wired or wirelessly.
Apr 05, 2008 | Brother MFC-665CW All-In-One InkJet...
Brother mfc 665cw connection error
I have a MFC665CW connected wirelessly to a router and a pc connected by ethernet to the router, with a broadband satellite receiver connected to the WAN port of the router (plan to add another PC to the network soon, so have set up the network in advance). I had trouble with the brother status montior flashing 'Ready' then 'Offline' all the time, when I knew the printer was always connected to the network. I had set up the DHCP stuff on the router to allocate IP addresses to everything that connects to the network, like you are supposed to. I updated drivers and firmware, but the problem continued.
When I checked the router status log I saw that one MAC address in the network was making a DHCP request every 5 minutes (i.e. it was asking the router to allocate it an IP address at regular intervals). Every time the router answered that request it made the Brother status monitor go 'offline'. The MAC address was my broadband modem. I fixed the issue by setting the router to allocate a static IP address to the MAC id for my broadband modem (in the DHCP setup section in the router's admin interface). That stopped the dynamic IP address requests from the broadband modem and the Brother status monitor works fine now. I also set static IP adresses for the printer and PC to be on the safe side, although I don't think that matters.
So, check your network log and look for a MAC id that makes regular DHCP requests and then set a static IP address for it. Hope this helps you guys too.
Mar 30, 2008 | Brother Multi-Function Center MFC-665CW...
Sharing printer
May your printer doesn't fit to your operating system because Windows Vista is one of the complicated OS and hard to find installer or software to fit it in. Try to Replace your operating system that same as your brother have. maybe it can fix your problem!
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Sharing printer between vista and xp os
Hi have a nice day.
I think tranfering your job to desktop first, and then sending to printer, is a solution for now.
Feb 22, 2008 | Microsoft Windows Vista Ultimate Edition
Brother MFC-665CW All-In-One InkJet Printer Logo
160 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
