Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Problem with bizhub 350
Every time it says "adding toner" and stop working. what is the solution?
Thanks.
  • Anonymous Mar 30, 2014
    keeps adding toner
  • 167 Answers
The solution is to place a service call.
It sounds like a component is not functioning properly thus causing a hardware crash
Posted on Jul 07, 2008
Hi. i have bizhub 350. my problem is the toner hopper is not spinning/rotating. hv already changed the developer,the toner replenishing box and the drum assy, whole unit. what seems to be my problem here....
Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series.
Mar 25, 2015 | Minolta bizhub 350 Black and White Copier
Code c255c after the f8 function
if you have a C2557 after changing F8 developer then your extra toner is too strong. Check your clutch adding toner, replace the small foam with an equivalent thickness, increase your toner and repeat a gain F8.
Feb 17, 2015 | Konica Minolta bizhub 350 All-In-One Laser...
ADDED TONER STILL ERROR ADD TONER
You can drop the toner cover and cheat the door sensor and watch the toner bottle to see if it spins or not. If it doesnt spin- the end result is not good especially if you have a grinding noise. or just the toner bottle not spinning and it asks to replace toner. The back of the machine will have to come off. You will have to remove all the covers and finisher off the front. Then get to the toner add mechanism and take it out. The one gear will probably be sideways because- if the customer put the toner in wrong or maybe the wrong toner in- it will bind and bend that back shaft. thereby screwing it up. It takes a lot of time and parts. First thing you need to do though- is to see if the bottle is spinning or not
Jul 25, 2012 | Minolta bizhub 250 Black and White Copier
Konicaminolta bizhub 600 machine dropping the toner. what is the solutions?
first toner must must and must be genuine, other wise it wont work in any conditions,
2nd toner density sensors and gamma sensor should be cleaned and all auto setting must be run .
third some time toner drops down the others side of the drum due to recycle clutch did't not work properly and all cleaned toner drops down after filled in recycle area,
Jan 11, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 250: is the waste toner box at top of drum unit?
there is no waste toner box in bizhub 250/350.the thing which you are calling the waste box is not a waste box.that thing is "Toner Recycling".
Aug 04, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 350 doesn't print at night.
Check the driver, you should have availability.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Aug 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printers with full bleed capability?
NO!
Just like on a printing press that toner is being imaged somewhere when it runs out of the sheet. The toner is going on the imaging belt/fuser. Over time it will build up and ruin the device. On a press they can stop and wash the imaging blankets. Full bleed is achieved by running on oversized stock and trimming off excess afterwards. That is how the "Pros" do it.
Apr 13, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Apr 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
77 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
