FixYa.com
Tags:
Kenmore 22422 Top Load Washer
Hjh
posted by Tucky93 on Jul 06, 2008
hjh
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 07, 2008
Not Rated (0)
shaggyrat
Rank:Wiz Wiz
Rating: 82%, 477 votes
kinked hose adjust hose so unkinked
or water pump clogged sometimes socks get past drum into water pump
water pump sends the water out
these are the main reasons the washers wont drain
couple things needed for pump removal
bucket and a couple small cups
pull water out
once low disconnect power turn the water off disconnect
you will need someone strong and a dolly
take out side the little water left in will make washer heavy
once outside tip back lay down on side angled up a little pull pump out pull debry out with needle nose pliars 2 people needed here then put pump back in done
this is self service solution
this can be done without service person
or you could call maytag
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
Washing machine problem
My washing machine trips the... Answer This...
kenmore ultra 2 dishwasher
inside the door where u put the... Answer This...
Need help fast w/ older...
We have a nearly 40 year old... Answer This...
I DONT HAVE A CATALOG
i cant use perfect.really i... Answer This...
Can not format my Sansa E250r
I want to format it so I can... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
