Question about Dell Latitude D600 Notebook
AC popwer adapter type cannpt be determined
It appears no adapter works with it and when trying to flash bios, i am warned to fix battery and adapter even though both are connected properly.
meanwhile, the same adapter charged another laptop.
what may be wrong?
  • b2mcene Jul 06, 2008
    i liked ur info.
    i'm in Nigeria and i think that problem is quite huge. thanks 4 the suggestion.
    another professional like me feels the charging IC or chip needs 2 be changed.
  • 3,940 Answers
It is a pretty common failure, the power connection to the motherboard is cracked or broken and the Motherboard is no longer detecting the AC adapter.
Many places on Ebay advertise power jack repair service for about $100.
I also found motherboards for the D600 on ebay for about the same price. I chose the new motherboard option.
Of course, if the system is under warranty, contact Dell for repairs.
Posted on Jul 06, 2008
  • IQUIT Jul 06, 2008
    Repairs at that level are beyond my capability, and frankly I've found that in the long run, replacing the effected componet is the most efffective resolve. Good luck
I have a DELL Vostro 1500 laptop, since the last 2 weeks it appeared a message when i turn on my laptop, it says: " The AC power adapter wattage and type cannot be determined. The battery...
Certain models talk to a chip in the adapter, sounds like this one has gone bad. At this point you can live with, buy a new one or pick up a used. This is a fairly popular model and you should be able to locate one from a dead laptop.
Mar 06, 2017 | Dell Vostro 1500 Notebook
When try t charge my battery in my Vostro 1000, I get a message " The battery cannot be identified the system will not be able to cahrge the battery
Try this first:
Use up the battery until the the screen would black out. Afterwards, reboot the laptop ( without using the AC adaptor) and the system will warn you of low battery - to press F1. After pressing F1, plugged the AC adaptor back and try rebooting.
If the above does not work, there is a Bios update from Dell that suppose to fix this problem.
Oct 20, 2010 | Dell Vostro 1000 Notebook
Dell E1705 will not charge aftermarket battery. Is there any work around. AC adapter is ok.
Hi there!
Try to check a few things first.
Go to the BIOS set up, which you can access by pressing f2 when you start up the computer,
Then go to the option that says battery info,
Check if the ac adapter is detected,
And check if the battery is detected,
If any of this things is not detected
Then try this things,
If in the ac adapter it says unknown,
boot to your windows normally
then make sure you still have at least
12% on the battery charge.
Then download the latest flash BIOS
update your BIOS then after you update it,
it should fix your not charging issue and fix the unknown ac adapter if ever that's the case,
But after you do that and the same thing happens,
You'll need to replace the motherboard of that computer.
Hope this helps!
Apr 13, 2010 | Dell Inspiron E1705 Notebook
Bios not updated -ac adapter not charge
1. you can download the bios update from the site
2. select the support for users
3. click on drivers and downloads
4. enter your service tag (service tag can be found underneath the laptop which is in a sticker)
5. after you enter the tag you click on go then it will list down the drivers and updates. try scrolling down look for bios then download via browser then select a location where to save the file. After the download double-clicked or right click on the file then run as administrator. (before flashing the bios make sure ac adapter and battery are plug-in and battery should be at least 10%) in case battery is no longer charging but laptop is working fine with ac adapter battery needs replacement. if the error message says ac adapter is not determine then just update the bios.
Mar 28, 2010 | Dell Inspiron 1501 Notebook
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Nov 11, 2009 | Dell Inspiron 1521 Laptop
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
it dose the same to me... and i fixed it by changing the charger.
Sep 21, 2008 | Dell Inspiron 1501 Notebook
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
Dell Latitude D600 Notebook Logo
65 people viewed this question
Alun Cox
