Question about Navman GPS
Screen is showing computer, usb connection, navman which are joined together by a serious of dots with the computer screen to usb connection showing green lights
  • garjo Jul 06, 2008
    Thank you for that information but I have a Navman F10. Do I still do the same thing.
    Can not remove the casing and there is no pin hole, what now
    Genius:
  • 2,035 Answers
Please unplug the usb cable and check if it is having the doted screen ,please reinstall the software in your computer and then plug it back if the dots are there ,please use this link to get latest drivers:
http://www.navman.com/
Posted on Jul 06, 2008
    Brigadier General:
  • 6,966 Answers
It is possible that your unit has sustained a firmware glitch and therefore has locked in the current function. I would suggest a systems/hard reset. Without a specific model, most I can suggest at the moment is to look for a small recessed pinhole (if present). Additionally you can try removing the power/battery and wait for a couple of minutes before trying, that is to dissipate whatever residualpower maybe left inside. Doing so would revert the unit back to factory default but of course would also delete all user configurations and settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Scholar:
  • 135 Answers
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
  • Harrish Mugundhan Jul 06, 2008
    F10 is an entirely different beast, not a single thing in common with F20-50.
    sir.i think there is no connection or an error in communicating with the navam n the usb connection so that data is not transfered properly.
    i likely advise u to ensure the connection properly,reset the system to default settings.
    Also pl update ur navdesk software
    thanks for using Fixya..
    have a nice day
    If your F10 displays the USB screen please reset your unit. To do this press and hold down the Power Button for 10 seconds, the unit will switch itself off. Please re-start your unit as normal
Not starting up has a computer link showing
Needs to be connected to a computer or laptop which has navman software installed so it can update the firmware and maps.just go to navman site and download all above for your model THEN connect with the right cable.follow on screen instructions.
Oct 23, 2014 | Navman GPS
How to fix stuck on transfer screen
Hold down the on button until the screen goes black. wait two min, then turn it back on. If that doesn't work, try connecting your device to your computer and go online to the manufacture website. Most have a way to check your device and fix/update it.
Sep 01, 2014 | GPS
We switch it on and the only thing that shows on th screen is a picture of the navman and a computer with dot's going backwards and forwards.
Try this:
1. Connect your device to the computer 2. Make a backup of your addresses and favorites if you wish 3. In File Explorer, right click on the device (removable drive) >> Format 4. Start the Desktop 5. Go to Tools >> Reinstall the software 6. Go to Tools >> Recover Keys 7. Go to Voice Transfer and re-install the voice files 8. Reinstall the maps
Feb 08, 2011 | Navman S30 Car GPS Receiver
Navman My50T - screen has frozen, can't get any other screen apart from initial start-up screen (except for screen showing connected to computer when connected by usb).
Had a similar problem with a MY60T.
Spoke to Navman support.
1. Connect your unit to the computer.
2. Use windows explorer to go to the Navman folder
3. Go to the database folder.
4. Delete "Database.db"
5. Switch off & re-start you unit. The databse file is re-created on startup
Dec 24, 2010 | GPS
Navman MY75T was working fine for several weeks, but today it won't start up. Tried to reset several times, but no luck. It gets to the Safety Agreement screen, and when I press the "Accept"...
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
Nov 02, 2010 | GPS
I have a navman s90i . When i plug the car charger in the screen shows a compuyer runing into a navman via a cable then shuts down then try's to start but goes to the above screen
No solution but exactly the same model and exactly the same problem. When I put the car charger on the unit, it goes off and then comes back on and ust shows a computer as though the only option it can handle via usb is a computer connection. Interestingly, it still charges, but just becomes useless as a satnav as there are no maps, directions or any scree functionality at all.
Nov 22, 2008 | Navman GPS
Navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Jun 10, 2008 | Navman F20 GPS Receiver
Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
May 11, 2008 | Navman iCN 520 GPS Receiver
Navman S50 wont load maps
Hi, my probelm is very similar I turn it on and it shows a laptop, usb connection and the navman with a usb cable connecting them together,it also has circle running back an fourth
Feb 08, 2008 | GPS
Navman f10
i was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
pamelathanson@aol.com
Dec 28, 2007 | Navman Tracker 5500i GPS Receiver
GPS Logo
686 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
