Question about Sharp Microwave Ovens
The oven works ok on coventional mode,but not microwave,the fan and light comes on but thats it.small fuse gone at the back ,these wires trace back to the board
  • Sharp Master
  • 9,098 Answers
So the turntable doesn't turn when you try to microwave?
Then that would probably indicate a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If your symptoms differ, please reply back with your brand and model number and more details so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
I have a Whirlpool MH7130XEQ-1 microwave. Sometimes it doesn't start. Sometimes the timer works, but nothing else happens. Sometimes it works perfectly. What could be the problem. Other times the fan...
hello,
what this means is partial contact problem from the internal wire from the power supply.
however, what you need to do tofix up your oven back to live i to unscrew your your oven from the luck key (stroll) and then trace down the wire to the element i.e heat provider and the fan to see which wire has gone wrong .
please before you can carry out this function you will have to disconnect any form of power supply on the oven.
thank you and thanks for using fixya.
Jun 01, 2010 | Whirlpool MH7130XE Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Check this one out! My GE Profile microwave heats up but I don't hear the fan. However, the inside light and the turntable stopped working at the same time. Everything else seems to be working fine. What's...
hello,
this is a maize problem that wiring (wire) this means that your oven fan has been disconnected from it position
what you need to fix up your fan back is that you unscrew your oven trace the maize that supply A/C to the microwave
this maize is connected to different object but what by you are real after is your fan and the heater including the turntable .
trace the wire down to the fan to locate the loss wire from it position and do the fixing your self because it is same maize thaat link up both together i.e fan and turning table
please note before you can do this make sure that any form of power supply is put off.
Good luck and thank for using fixya.
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
After a power outage in the house the microwave went dead. There is no display. When you open the door the light turns on and the fan turns on. I opened it up and the fuse is o.k. I noticed that there is a...
Usually if there was enough power to burn the traces then it usually will damage a few things. It's worth a try to fix the trace. If it works don't be too surprised if it fails later on.
Apr 28, 2010 | Panasonic NN-S762 Microwave Oven
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
Majic Chef cabinet mounted microwave oven model VM11B-8P
On the electronic control board, the circuit trace will open like a fuse if the light bulb power becomes shorted. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for a burned, open circuit trace.
4. Repair circuit trace everything should work again....
Jun 15, 2008 | KitchenAid KCMS145J Microwave Oven
Turntable, lights and fan inop
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef mco153ubf
I had the same problem. My Magic Chef, MCO153UBF Microwave had similar problems. The Magnatron, Cooling fan, Turn table and under hood lights were not working at all after hearing a pop sound under the control panel. Thought it was the fuse but the fuse was fine after testing and replacing. I checked the circuit breaker wired to my house and saw it had a break to my kitchen outlets so i flipped the switch to get back the kitchen outlets. Then I checked the microwaves Control Panel ( Printed Circuit Board) underneath and saw to traces were burnt. I soldered the two trace lines and the fixed the problem.
Nov 19, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
