Question about Dishwashers
Often had to press 'Start' up to 5 times to get it going. All lights light up but then go out. Occasionally the pump would run for a minute or so then whole shooting match would close down. Recently we were lucky and it filled with water but sadly disappointed when it closed down again. 8 people in the house so had to do the dishes in the sink (again!!). Plenty of helpers and a glass or two of wine so things weren't that bad. Not good for Dishlex though especially when others say theirs are not Dishlex, are older and still going. No, not the child lock - have managed to set and unset that a couple of times and still won't pump out. Pump seems to be running but no output then shuts down again. No serviceman available for another ten days. Is this a common fault? Lady who took the call seemed rather aware of our predicament and blogs on the Dishlex Global 300 site suggests so. Can someone help with a bit of advice please? Many thanks in anticipation. PaulN.
Problem not solved yet.
Cleaned the filters well, hoses clear and water delivery happens.
Both pumps work happily so are not seized/locked up or have anything jambed in them (pulled them both out and checked for foreign objects and impellor operation).
Seems to be in the contol panel so with lack of time available to me now due to the number of other ocmmittments, I will await the servicman to call next week.
Only two of us till Friday so I think we can cope.
Thanks for your offer to assist though.
If the serviceman wants to charge $400 I'll throw them both down the front stairs. It's not worth that much - will buy another (but alternative brand) on e-Bay if that's the case.
What I will do though, is post the repairs on this site once completed so all will know.
Regards
Blindy
Posted on Jul 08, 2008
2006 GMC Denali truck starts fine. about 5 minutes in I get weird dashlights and then all lights out and needles go left
That's 1 of the years that the instrument clusters after a period of time need replacing. There wasn't a recall but there should have been.
Jul 10, 2017 | GMC Yukon Denali Cars & Trucks
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Kenmore model 665.15829 Air dry lock button light is on. Washer won't start. tried different codes to reset. no luck. when I pushpots pans button and start it goes into sensor mode and tries to pump...
Hello. There is a master reset code that should work for your machine. Here it is reset is as follows-Press normal wash and heated dry one after the other about 5 times.All lights on panel will light.Wait until all lights go out and it resets itself.It will go into a mode on it's own.Then press cancel and set your options as you normally would and press start.
Best regards, Joe.
Nov 09, 2009 | Dishwashers
Occasionally Battery light goes on momentarily
could be a defective alternator, but the mechanic will need to check it while the light is on. I know that sound like BS but if he checks it while the light is off, of course its going to check good.
Sep 21, 2009 | 1992 Honda Accord
After going thru the Start up set up our Intex
After setting the time did you remember to re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep? Several minutes later the Green LED should come on indicating the cycle has started.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Vehicle No Start - no turnover (lights, radio work) then it starts
It may be your harmonic balance. do you hear a rattling noise when it runs?
If not it could be a bad or going bad starter.
Oct 01, 2008 | 1994 Oldsmobile 88
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
112 people viewed this question
Top Dishwashers Experts
