Question about Samsung Televison & Video
Samsung 105" RP have to keep setting convergance each time i switch on??? model No sp-43t6hp
  • spudy40 Jul 12, 2008
    yes i have to set every time i switch on
    Guru:
  • 1,894 Answers
Do you mean that the setitngs are not getting saved eac time you set it?
am i right.?
Posted on Jul 08, 2008
Ihi i have a samsung sp 43t6hp and it looks like im watching tv in 3d how could i fix the problem
Sounds like you need a convergence board. Problem is there might be some transistors that you need as well. I've had a similar issue. Most places will cost $300+ to replace what might be a $15 part. Also there are 2 transistors in there that need to be replaced at the same time (once one goes the other is likely to as well). I would suggest calling Sears to fix it. They charge much less for the visit ($99 min charge) and will replace both parts at the same time.
Sorry I know that's not a true answer on how to replace the convergence board or other parts but mucking around in a rear project tv is a good way to get shocked. Those TV's hold a lot of charge even after unplugging.
http://www.searshomeservices.com/televisions/repair
Mar 03, 2011 | Samsung HCL652W 65" Rear Projection...
Hello, I have a Hitachi 42" RP, model #SP-43H. All of a sudden the color on the screen is distorted and is creating a double immage in Red and blue'ish green. Any advice as to what I need to repair this? ...
Common problems on DLP projection tvs.This problems is known as a convergence problems,it dead.The colors lines R,G,B mis alignment,colors shadows pictures and 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 02, 2010 | Hitachi Televison & Video
I have a Samsung Model PCN5425R Rear Projection TV. When I try to set the convergence, the red will not move whatever I do, but the blue works fine.
If it is rear projection set it uses either two of the STK-392-020 OR STK-392-040 CHIPS FOR CONVERGENCE OUTPUT.
BOTH WILL HAVE TO BE REPLACED; NOTE THAT THESE SETS ALSO HAVE "PICO" FUSES ON THE BOARD FOR EACH CHIP--no movement means one of the fuses is blown because the chip shorted.
This can be a do it yourself repair if you are handy; total parts cost if the parts purchased on Ebay is under 30 dollars.
Let me know if I can assist you and if you have any questions reply to the posting here.
REGARDS, SD TECH
Aug 10, 2010 | Samsung PCN5425R 54" Rear Projection...
Double image
it is not majer problum. this is a convergence problum pls read user"s menual and set convergence seting on the remot control.
if not posibal convergence seting then inside the fornt cover 6 pre-set Adjesting 3 pre-set on top is foucas Adjment.
and 3 pre-set bouttom is screen Adjesment for R_G_B. Gun. set perfact Adjestment.
Oct 04, 2009 | Samsung Televison & Video
Samsung Rear Projection TV Model No SP-43T5hp
How are you going?
Your repair solution is to replace STK392-040 convergence
IC's.........I use Panasonic brand for reliability or use Samsung
but no generics....they don't wear long........T.
Dec 10, 2007 | Televison & Video
Convergence
you have a samsung? hcl4715... your convergence chips have most likely blown...sorry..
Dec 08, 2007 | Samsung HCL4715W 47" Rear Projection...
SAMSUNG TANTUS
Start with SAMSUNG.com---I had trouble with the model # you gave----?? Can your circuitry be repaired??If no,why???
Oct 08, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
26 people viewed this question
Henry  Thomas
Henry Thomas
