Question about Sony SDM-HS75 17" LCD Monitor
SONY SDM S81R
I have a problem with the backlight of this monitor.
The monitor is black.
He recognizes the input of the PC and turns on the 5 V signal on pin 7 of the High voltage inverter, but no light.
The power supply is ok and delivers his voltage to the inverter.
Are there any schematics somewhere?
Many thanks for your help.
PS could not find the correct model in the list, but the monitir is a SDM S81R silver
Marc.
  • mkieffer Jul 06, 2008
    Great people on this site.
    Thanks Zwarrior.
    Ideed the FT Fuse beside the R1 resistor was blown.
    Was just the blimp to find out what kind of fuse.
    The panel consumes 1 Amp with no input, just showing the typical "check connection" message.
    With normal picture it's 2.6 Amps reading on the lab.power supply.
    I'll put a 3 amp one in place.
    Thanks again and a nice day to all the community.
    Marc
    Luxembourg.
    Scholar:
  • 135 Answers
Hello sir,,
since there is a problem with the monitor..u have to contact the sony vendor ,
u can contact them in 800-326-9551
n also 888-476-6972..
thank you
have a great day
Posted on Jul 06, 2008
  • Harrish Mugundhan Jul 06, 2008
    And for precisely for computer monitor u can catch sony guys on 800-488-7669
    thanking you
    Sir i did my homework on internet n i found this:::
    I believe there is a company called LCDPART.COM has lists many
    types of inverter boards.
    If you are good with electronics, I would suggest that you check the
    inverter board before buying a new one. I have had 3 or 4 where
    just the SMD fuse was blown. Often the SMD driver transistors that drive the transformers at the ends of the board are shorted, causing the fuse to blow.
    Hope this helps....
Hello, My SONY TFT SDM-P82 monitor just blacked out? Help???
<P>It can be the power supply caps or the backlight inverter circuits, or worst case will be the lamp assemblies.</P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <A href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.<o:p></o:p></SPAN></P><P style="tab-stops: 351.95pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <SPAN style="mso-spacerun: yes">&nbsp;</SPAN><A href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Aug 26, 2010 | Sony PremierPro SDM-P82/B (Black, Silver)...
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Sony SDM-HS75 tft lcd monitor
Sounds like you need a new backlight. Check lcdparts.net
May 26, 2009 | Sony SDM-HS75 17" LCD Monitor
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
I need a Replacement Fuse for SDM-S81R Stylepro Monitor
Take the fuse out , go to an electronics parts store, like RadioShack and match up the fuse.
Jan 25, 2009 | Sony STYLEPRO SDM-S81R (Gray) 18.1" LCD...
MY SONY SDM-HS74P
You open the inverter unit and check any dry soldering is there. Some times dry joints inside the inverter unit cause this type of problems.
Apr 06, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Oct 17, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Sony SDM-HS75 17" LCD Monitor Logo
266 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
