Question about Goldstar Refrigerators
Refrigulator Malfunction Dear Sir; My refrigulator has found not "cold" in normal storage room. Brand: Gold Star, Model:GR-462FVC. But in good working condition in the "Freezing" panel. - Upper door. Please give me advise that which part should i make replacement and whether it is worth to repair ?
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
  • Mike Durland
    Mike Durland Jul 10, 2008
    • none of my free suggestions have helped you at all?
    •  if you feel the issue with the machine is something else let me know, i will try to help you figure it out.
    Mike
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
I have a R5203 gold star air conditioner, and the room does not get cold any more, also do you have to replace any fluids, its sounds dry and crackling.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 17, 2011 | Goldstar R5203 Air Conditioner
Freezer is hot on the sides is this normal?
Good day,
Yes, that is normal. It is ideal to not be in a hot room but as it reaches temperature and begins to cycle off and on it will become somewhat cooler.
Jul 20, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
We have a roper frig that we use for vaccine storage, the freezer does not stay cold enought for their storage; if we adjust to freezer temp for vaccines then refrigerator is too cold for storage
Good day,
Usually caused by the machine in a cool area or room, along with the machine not getting enough door action, both freezer and fresh food.
Domestic refrigerators are designed to be used as just that. Domestic refrigerators.
Normal kitchen temperatures, followed by minimum of 7 freezer door openings per day spread over 14 hours as well as 22 to 26 fresh food door openings over the same period of time.
In other words, it's not getting enough activity daily. Common problem in doctor offices.
The best model for that type of application in the past was the Amana bottom freezer model. where the primary control was located in the freezer, nailing the freezer temp, and the top controlled by a pneumatic damper controlling the fresh food section, but I do not know if their current model still uses that system.
One option,space permitting is a small chest type freezer added to what you have.
Mar 15, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Like to know if walmart are selling gold star brand or who is selling gold star
Hi... I've researched for answers to your questions and I've found out that Walmart and Gold Star sell dehumidifiers. Visit Walmart here. Gold Star Appliances here. Hope this helps... :D
Feb 03, 2010 | Dehumidifiers
Motor running, but freezer not freezing items.Second hand fridge was working from 10 Feb 2010 stopped freezing on the 19 Feb 2010 Gold Star GR 252 fds
First of all you have to check if the fan is working properly because this is the one responsible for "taking the cold out" from the evaporator and into the freezer
Jan 23, 2010 | Goldstar Refrigerators
I need to know the cubic feet of a Gold Star dorm size refridgerator model # GR-910W.
Hello there:
here is a link that will help you determine the cubic feet of the refrigerator
best regards michael
Goldstar Refrigerators Product Reviews and Prices - Epinions.com safe.gif Epinions.com - Find Goldstar Refrigerators ... Compact Refrigerator. Compact · Less than 5 cu. ft. (142 liter) · Opens Left and Right · Goldstar. See specs ...
www.epinions.com/Refrigerators-Goldstar - 18k - Cached
Aug 27, 2009 | Goldstar Refrigerators
JVC model - GR-D370AS driver
I am owning one JVC GR-D370AS.
I wanted to connect the same to Yahoo messenger to use as webcam
Aug 06, 2008 | JVC GR-D20EK Camcorder
JVC GR-DVL310 VISTA DRIVER
Your JVC is a MiniDV camcorder, which uses a Firewire connection for capture. Firewire drivers are standard for all DV camcorders, and built-in on every version of Windows since about Windows 98SE (well, they didn't work very well until Windows 2000).
You still need a capture application to complete the transfer. Most (maybe all) versions of Windows comes with Windows Movie Maker, which is a very basic program, but it can do this.
Normally, a DV camcoder can't be detected by Windows until you have it connected via Firewire, and have it the appropriate mode. On some cameras, this can be play or record (the latter would tranfer live video, or allow recording TO the camera), on others, you need to set the camera to a "link to PC" mode. I currently own Sony and Canon camcorders that both work in the former way, but my first DV camcorder was a JVC, and it did have to put in a "link to PC" mode to be detected by the computer. If you can't find the setting, you might want to check your user manual.
For still photos, it looks like you use a USB connection. I haven't found all the details on this camcorder, but this is likely to be a normal USB "storage class" connection. If so, your camcorder would show up like a disc drive, and you can drag photos over. Vista will support this by default, too.
The other way some older camcorders send photos is to appear to the system as a USB scanner type device. You would need a device driver for this, from JVC.
The user manual would be helpful here. You can get one via download if you don't have it:
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310U
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310UM
Jan 20, 2008 | JVC GR-DVL310 Mini DV Digital Camcorder
Refrigerators Logo
222 people viewed this question
Top Goldstar Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
