Reset to factory setting
Help me restore to factory setting. i accidentally pressed component video
  • Anonymous Aug 18, 2008
    Re: Pioneer DVD Recorder DVR-920H. I can't us the setup to start up the Guideplus facility (The setup menu does not appear at the top of the screen in Guideplus). I have tried resetting the player by unplugging when still turned on but this doesn't seem to make any difference..... is there a way of resetting to the original factory settings?
"Hold stop button pressed in front of the unit, and press power on the front".
Awesome!!! This fix worked for me. My player wouldn't read a disc, it only displayed a flashing "LOAD". plug the plug overnight and nothing. I tried the suggestion above and wah-lah! Success. I have a Toshiba SD-K860.
SM
Posted on Jun 07, 2010
Hold stop button pressed in front of the unit, and press power on the front.
Posted on Sep 09, 2008
How do I restore sound on my tv ?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2015 | Televison & Video
How do i unlocked my mini laptop?because its accidentally i locked.canyou pls help me?
You will need to factory restore, this will lose any stored data!
Start the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt-F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
5
Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
Dec 27, 2014 | Acer TravelMate Computers & Internet
Static noise
it is a faulty component humming inside. Need repair.
Oct 25, 2013 | HP Computers & Internet
How do I get my cable box to work on my mitsubishi medallion hdtv 1080. It worked before then my service was interuppted now all the tvs in my house work except this one.
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings. In the case of color inaccuracies, the TV's PerfectColor/PerfectTint capabilities can be reset by pressing the Menu button and using the right arrow key to highlight "PerfectColor." Press "Enter," then "Reset" to restore the factory settings. For issues with the audio or video of an incoming signal (DVD player or VCR), press "Menu" and use the right arrow key to highlight "Reset." This will restore the original factory settings for all incoming signals.
Jun 17, 2011 | Mitsubishi Televison & Video
I have a samsung u450, I am trying to reset my phone back to its factory settings. How do I go about doing that?
WARNING: Restoring the handset will permenently Delete All Data, including Contacts
Note: All locked pictures, videos, ringtones, music, sounds and downloaded content will be permenently deleted when restoring the handset to the default settings.
To restore the handset to the factory default settings follow the steps below:
  1. While in standby mode, press OK for Menu
  2. Select Settings & Tools (9)
  3. Select Phone Settings (6)
  4. Select Security (9)
  5. Enter the lock code, default password is the last 4 digits of cell phone number, unless it has been changed, then press OK
  6. Select Restore Phone (5)
  7. Highlight Yes, using the navigation keys
  8. Press OK to confirm resetting the handset
  9. Press OK at the re-program the phone screen
  10. Enter the lock code again, default password is the last 4 digits of cell phone number, unless it has been changed
  11. Press OK to confirm restoring the handset to the factory default settings
Note: Press *228 and SEND after the power cycle to re-program the phone
Hope this was helpful?
Jan 23, 2011 | Samsung SCH-U450 Cell Phone
When starting my new tomtom accidentally installed
hello. i recommend that you do a factory reset as follows: With the device turned off, press and hold the TALK/SEND, END and POWER buttons until you see a message on the screen. Release the TALK/SEND, END and POWER buttons. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset. Once the restore screen appears press Volume Up to restore the device to its factory settings or any other button to cancel. Once complete press Volume Up to reboot.
Nov 12, 2009 | GPS
Dvd's play with a distinct green tint
Check the component cable from the Bose to the TV, and confirm the output setting on the Bose. If it switched to "S" video it will look green. If your cable is good and your settings are correct, switch from component to standard video and check the picture. Chances are good that it's a setting. Hope this helps. If you still have a problem, post a comment and I will help you some more
Jul 02, 2009 | Bose 3 2 1 GSX System
My son accidentally used the restore factory settings. after that the buttons "X" and "O" switched function and some of the games too
re restore your settings (factory) then you should be good to if not hook it up to your computer and go to psp.com and look for the free software kk
get back to me
Mar 09, 2009 | Sony PlayStation Portable (PSP) Console
How to reset (manually) factory defaults?
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
Sincerely,
Michael Scott
Nov 16, 2008 | Protron PD-DVR100 DVD Recorder
Blank Monitor
Start pressing F8 at boot
When the Windows Startup menu appears, select ENABLE VGA MODE
This will boot the system in 640 x 480 resolution but the video driver will be installed. Once at the desktop, either reset the display to the normal resolution settings or reinstall the video driver.
Aug 06, 2008 | Relisys RLT1720 17" LCD Monitor
Televison & Video Logo
1,283 people viewed this question
Top Televison & Video Experts
Electro Med Services...
