Whenever you press the power button the modem does not turn on
    President:
  • 1,314 Answers
Assuming you are calling the tower itself the modem, then the fault here is in the power supply. You need to replace the power supply.
Posted on Jul 06, 2008
Login failed
if ever you know how to configure WAN and lan again, i would recommend to reset the router.
to reset router: put router on power, press the reset button, most of router manufacturer hides this button to avoid accidental press. in this case, you can use a pin to press it. once pressed, the led will all blink together. you are now in factory default of your router and you can start a fresh configuration.
Oct 04, 2013 | D-Link Dir-600l Wireless N 150m Home Cloud...
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Jun 29, 2011 | Arris SURFboard SB5101 Cable Modem
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    Red power light
    You need to hard reset your modem. By doing that, unplug the modem from the power outlet. Look at the back of the modem, you will see there a small red button. You need to press that button. You need to get a pin or pen to press that reset button. Press the reset button for 5 mins. Monitor the power light. It will change to orange light and it will restart. Once it restarted, you can release the reset button and wait for the lights to come up. Since you did the hard reset. You need to configure the modem with your username and password from your ISP.
    You need to access the gui or firmware of your modem. If it ask for username and password. This is the time you need to contact your ISP. They will help you to configure the modem. Once they provided you the username and password ofr your modem. Write it down so you will have a copy and in case it happen again you know what to do. Username and password for the modem is different from the username and password for your internet. You also need to enter the username and password for the internet so you can use the internet. If you get a red light for the internet, that means the username and password is incorrect.
    If this didnt work. You need to replace your modem.
    Apr 09, 2010 | Westell Wirespeed LiteLine 6100...
    Problem with gateway modem.Power light is red wireless light is green,Dsl and Ethernet lights are not on.I have turned everything off and back on.I have disconnected everything and put it back.Nothing...
    You need to hard reset the modem. By doing that, unplug the modem from the power outlet. Look at the back of the modem, you will see there a small red button. You need to press that button. You need to get a pin or pen to press that reset button. Press the reset button for 5 mins. Monitor the power light. It will change to orange light and it will restart. Once it restarted, you can release the reset button and wait for the lights to come up. Since you did the hard reset. You need to configure the modem with your username and password from your ISP.
    Mar 07, 2010 | 2wire (1000-000057-000) Modem
    I cannot turn my d1500t power on. though it seems like there is power running through it cause the ventilation is working and the light on the bulb sign is on, i cannot turn my laptop on whenever i press...
    remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
    Mar 07, 2010 | Computers & Internet
    My modem won't turn on.
    Either the power cord is bad, or your modem is fried. need to replace one or the other.
    Dec 08, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
    When I press standby button the standby led doesn't turn on
    First, make sure you have an internet connection. If so, shut down the modem. Pull out the power cable and Coax cable from the back of the modem. Then first put the power cable in, then the coax cable and then turn on the unit. Restart your computer to verify a connection. Then try to press the standby button. If this doesn't work call your internet provider and they can reset the modem remotely for you.
    Good Luck.
    Jul 08, 2009 | Arris SURFboard SB5120 Modem
    Motorola SB4200 Modem IP not working
    You can always do the 30-30-30 reset as follows:
    1. When router is powered on, press the reset button and hold for 30 seconds. (Use a paper clip or something sharp)
    2. While holding the reset button pressed, unplug the power of the router and hold the reset button for 30 seconds
    3. While still holding the reset button down, turn on the power to the unit again and hold for another 30 seconds.
    This should allow for a full reset of the modem. Once that's done, connect your computer to it with an Ethernet cable to access it's WebUI using the Default Gateway (192.168.100.1), or connect to the WIFI using the default SSID and Password that are usually written on the modem itself.
    I hope this works!
    Sep 07, 2017 | Arris SURFboard SB4200 Modem
    Computers & Internet Logo
    22 people viewed this question
    David Payne
    David Payne
