Question about Fuji FinePix E500 Digital Camera
Problems with the display
when I turn on the camera I only see a USB-sign and below a symbol which shows two arrows (like a changing-symbol) and a "DSC".
When I press any button nothing happens. I already changed the batteries and I also ejected the card and waited a while before I turned it back. The result is the same.
With kind regards
Jessica Obermann
5 Suggested Answers
  • 188 Answers
SOURCE: No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
Posted on Jul 09, 2006
SOURCE: My camera wont turn on
Well sometimes my camera does basically the same thing as both these comments and it is the battery quality.
Posted on Jun 14, 2008
Benimur
  • 6966 Answers
SOURCE: Unable to access menu
Hi and welcome to FixYa,
Initially, it would appear that all the hardware perform nominally. This would then indicate that it is the software half that has some glitch. The software/firmware normally could be re-flashed or updated but would require specialize equipment/interface which are not readily available to most user(s).
This then would require the services of an authorized service center for Fuji digital cameras capable of handling your camera's specific requirement. If the cost of repairs and downtime would be factored in, then you may have to re-evaluate your options of having it repaired and/or consider a replacement.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 01, 2009
SOURCE: my camera dosnt turn on only the green light comes on....
Do you have it on viewfinder or lcd screen ?
Posted on Apr 26, 2010
How do I turn off the flash on my Cannon pouershopt SD1000?
Hello and Welcome to FixYa!
To turn off the flash follow the given steps:-
  • Turn on your Canon PowerShot SD1000 Digital Camera
  • Press the Flash Right Arrow button on the four-way control on the back of your camera to display flash options on the camera's LCD screen
  • Now push the Left Arrow or Right Arrow button to select the flash "OFF" icon. It's the third icon that display the flash symbol crossed out by a backslash symbol inside the circle.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep using FixYa!
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
When I turn the camera on it displays USB sign and a picture of the mempry card , a two way arrow and DSC. If i take the card out and try to start the camera it does the same. I have tried different cards...
Hello
Try to clean the contacts of memory card at camera, as the camera does not recognize the any memory card, if it not works then the camera need repair of some disconnection of memory card contacts inside the camera.
Good Luck
Dec 30, 2010 | Fuji FinePix E500 Digital Camera
Programming timer
SETTING THE MACHINE TO TURN ON
1. Make sure the dehumidifier is plugged in but turned off.
2. Press the button with the clock symbol below it.
3. Press the up arrow to set how many hours until you want the machine to turn ON. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
4. After you have stopped pressing the arrow buttons the display will return to the original display showing temperature and relative humidity.
5. After the above steps are completed the dehumidifier will turn ON in the number of hours that you have set (programmed).
SETTING THE MACHINE TO TURN OFF
1. Make sure the dehumidifier is plugged in and running. You should hear the fan blowing for sure.
3. Press the up arrow to set how many hours until you want the machine to turn OFF. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
5. After the above steps are completed the dehumidifier will turn OFF in the number of hours that you have set (programmed).
Jun 21, 2010 | Danby DDR5009REE Dehumidifier
Not connecting to laptop
Hello!
Please consider the steps given below to troubleshoot the issue while connecting the Camera to the HP Computer using a USB cable.
(i) Before connecting the Camera to the Computer, first initialize the Camera to the original factory settings by following the steps given below:
(a) Turn ON the Camera then press the Home button to display the home screen.
(b) Select Settings with left/right arrow on the control button.
(c) Select Main Settings 1 by using up/down arrow on the control button.
(d) Next, select Initialize and OK.
Performing the above steps will reset the Camera to the original factory settings. After resetting the Camera to the original factory settings, turn off the Camera and remove the battery pack then press and hold the power button for 30 seconds.
(ii) Then, reinsert the Battery pack and turn ON the Camera and press the Home button. Select Settings using the left/right arrow on the Control button.
(iii) Next, select the Main Settings 2 option then select "USB Connect".
(iii) In the USB connect, please select the "PTP/MTP" option.
(iv) Next, connect the Camera to the Computer using the supplied USB cable to get it recognized. Please make sure that the Computer is recognizing other USB devices when connected to it.
If the Computer still doesn't recognize the Camera then check in the Device Manager window for any exclamation mark.
Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box. Then, please type "devmgmt.msc" in the Run dialog box and click OK to open the Device Manager window. In the Device manager, click on the plus sign next to each category and check for any exclamation mark, if there is any then right click on the device and click uninstall. After uninstalling all the devices with the exclamation mark in the Device Manager, please restart the Computer with the Camera remain connected.
After restarting the Computer, the Camera should be listed in the Computer window (windows logo+E key) as a removable drive.
If the issue persists even after performing all the above steps then the issue may be related to the Operating System. In that case, you may try reinstalling the Windows.
Aug 22, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Plotting two graphs
Go into the Y= editor by pressing the Y= key. Select a function, then press the left-arrow a couple of times. Now press ENTER and see whether the symbol on the far left changes. If so, you've just changed the function style. Press ENTER repeatedly to select the function style. Your choices are Line, Thick, Above, Below, Path, Animate, and Dot.
Nov 21, 2008 | Texas Instruments TI-84 Plus Calculator
What should I do if my PC still won't recognize the camera after I reinstalled the USB drivers?
If the camera is still not recognized after the USB driver has been re-installed, one of the following situations may apply. "PC Camera" may be selected as the USB setting on the digital camera. Change the USB setting to DSC or select DSC in USB MODE. (This only applies to models with a USB Setting or USB MODE option in the SETUP screen.) Does the LCD monitor on the digital camera show that the USB connection is active (USB, DSC or a USB symbol with an arrow, etc.)? If not, the digital camera and PC may not be connected correctly. Check the items listed below. a) Restart the PC and reconnect the USB cable. b) If the PC has multiple USB ports, connect the cable to a different USB port. If steps a) and b) have both been tried and there is still no USB connection indicator displayed on the LCD monitor, there may be a problem with the digital camera or USB cable. Contact an authorized Fujifilm service center and ask them to check the digital camera together with the USB cable. Refer to the Digital Equipment Repair page for information such as the procedure for requesting checks and the locations of authorized Fujifilm service outlets. The USB driver may not be installed correctly. Download the USB driver from the Digital Camera Downloads page and re-install the driver The camera may not be recognized correctly if it is connected to an added USB interface board or via a USB hub. Always connect the camera directly to the USB port on the PC.
Aug 30, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Fuji FinePix E500 Digital Camera Logo
48 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
