Question about Bang and Olufsen Beocenter 9300 Shelf System
Beovision 7 broken dvd player
Hi
When I try to open the dvd player it just drops doen but will not swing open, any ideas?
Thanks
  • BNO_reo Nov 26, 2008
    Do you have the ability to dump the eeprom of the Beovision 7 Type : 9354 ??
    do u perhaps have schematics and or board layout for this model ?
    i am trying to unlock my Beovision 7
  • Anonymous Mar 19, 2009
  • 122 Answers
All dvd problems are resolved by dvd mech. replacement/exchange,see your local dealer
Posted on Jan 11, 2010
Beovision
There are no user serviceable parts on these flat panel tvs.
Use your warranty if available. This is why buying the extended warranty on expensive electronics is a good policy.
Find a nearby electronics repair shop and get it checked over.
Mar 25, 2014 | Televison & Video
B&O DVD1 PLAYER DOES NOT OPEN ON DEPRESSING EJECT. NO DVD IN IN THE PLAYER. CONNECTED TO B&O BEOVISION. HAVE TRIED DISCONNECTING POWER. ANY SUGGESTIONS?
if disconnecting power does not help then you will have to open the player and make the DVD tray roll out.
Aug 05, 2008 | Televison & Video
Hi I have a portable Logik DVD player 7DualM11 7"
try to use a lens cleaner and look at the close sensor
Oct 28, 2012 | Televison & Video
I have a JWIN VD519 DVD player that has worked fine till this evening. The remote suddenly stopped responding even after changing for new AAA duracell batteries. Nothing has been spilt on the remote...
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
Sep 05, 2011 | Jwin JD-VD149 DVD Player
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
Beovision 7-32 with integrated DVD player won't load DVD's. Tray closes, but won't load the disc and opens again.
Beovision 7-40 i've got has done the same thing.... it will cost me around £600 to replace. the say they dont repair it they just replace it, how rubbish is that! what is the type number of your beovision 7 ? as i might be able to help you.
Nov 01, 2009 | Televison & Video
My element blue ray dvd remote is not working, can you tell me what can I do
Quick fixes-
-New batteries
-Batteries inserted incorrectly
-Not aiming at reader
More difficult to fix
-Non compatible remote
-Broken LCD sensor
-Circuit issues
-Water damage
Please contact me if you figure out the exact problem, and I will help you to fixit
Oct 11, 2009 | Element Electronics EDBCO11 Blu-Ray Player
DVD player was dropped and scene is broken. Can it be repaired? Sxion 7" LCD monitor and DVD Player
it can be reapired , simply a case of replacing the lcd screen, the harder thing may be finding a lcd screen, contact the manufacturer, and they should be able to direct you to their closest authorised service agent. good luck.
Aug 16, 2009 | Axion AXN-6075 7 in. Portable DVD Player
Wrong region
Hi , The reason for the error message is because your DVD player is set to one specific zone. The below procesure will open the DVD player to play all zones.
TURN ON THE PLAYER
PRESS OPEN/CLOSE
USING REMOTE PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL APPEAR. PRESS "0" TO UNLOCK (OPEN the DVD player to ALL zones) ALL, THEN WAIT. INSERT YOUR DISC. Hope this helps. Let me know the status. Thanks, Mike
Nov 03, 2008 | Audio Players & Recorders
319 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
