Question about Hotpoint WMA40 Front Load Washer
Very noisy machine very noisy and not sure how to removed back to check drum, is this a sealed unit
  • 108 Answers
The washer is not a sealed unit but the rear drum bearing are also you will need a new spider...To take a look inside - Initially you will see enough from the top to see where things are...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If the Drum bearing has failed it is usually due to over loading or a faulty seal in the drum, water leaks into the inner bearing. This causes corrosion and then ultimately failure.
In the likely event that the bearings have failed (I have had a hotpoint wma33 fail at 23 months...) Its actually cheaper for you to pay hotpoint to fit a new drum (Parts are free for 5 years! you just pay a flat callout fee - believe me its a bargin). + they never ever replacing just bearings, it takes too long for them. They will do a whole drum and spider arrangement in under 2 hours...
I wasted 3 days because these things are really awkward to remove and refit. The callout fee for a hotpoint engineer a fixed cost. I bought a spider see:
http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=954798&brand=&model=wma33&part=spider
This spider costs 61.25 + delivery - ouch.
I bough a half drum thinking I would keep the costs down. Hotpoint will fit half a drum or full drum (Depending on what is on the van for their call out fee) the actual cost of a half drum is 75.99 + delivery see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639770&brand=&model=wma33&part=drum
and a full drum costs 161.49 + delivery
see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639763&brand=&model=wma33&part=drum
They take away all the rubbish at the end also!
I know this site is about doing it yourself and I can go into more details about how to do it. But because I did not have the correct tools that hotpoint must have to pull the bearings from the housing etc - I feel I would be wasting your time.
I hope this helps
Please don't rate me as unhelpful, this is not a simple change the bearings task.
Posted on Jul 16, 2008
Is it possible to change the bearings on this model?
sealed units are separate to the tub and drum
I would first remove everything down to the outside drum as the noise could be from an obstruction ( coin/s bra wire, metal objects etc)
At 3 years I would not expect bearing trouble in a sealed unit so explore all other avenues of the noise first
bearings will be noisy at all cycles and not specifically at high speed spin
before you touch it -check the warranty period and if inside that period call the technician
Feb 10, 2016 | Hotpoint Washing Machines
When i load my washer drum in washer will not agitate or spin off tract.
if noisy like plane taking off bearings gone check play on drum by pushing drum back and forth look for large gap between drum and door seal and listen for scratching noise when turning also some machines wont spin if the load is uneven
Dec 12, 2014 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
My LDE7314 Maytag Dryer is making a noise which sounds like a squeaky belt or tension pulley. How do I open this unit to get inside and check to see what is the problem?
Hi rmbancroft...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Note: This method workds for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Jul 18, 2011 | Maytag Dryers
It sounds like one of the belts is broken. It is very noisy if there aren't a lot of items being dryed. This dryer is pretty new, but after warranty. : ( Thank you.
Hi krisbri05...
Your problem does not sound like a broken belt because there is only one belt on the dryer, and if the dryer is still turning then the belt is ok.
It sounds to me like you have a drum roller that is getting noisy.
I will send you the info on a drum belt replacement, but I will also include the replacement of the drum rollers if needed
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley. If you get into a problem with remembering how the belt goes on here is a link to show you a picture of how to route your belt.
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a Vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
Jul 17, 2011 | Whirlpool Dryers
The belt that rotates the drum broke. How do I remove the Back to replace the belt ?
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Oct 04, 2010 | Kenmore 64902 Electric Dryer
On a series 90 kenmore dryer where is the belt front or back
Anwer to your question: Front
Basic Information...
Sep 30, 2010 | Kenmore 64952 Electric Dryer
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Noisy bearing on drum
    This is not an easy job on any washing machine. The AEG is probably the same as most washing machines in that it has two bearings on the shaft at the rear of the drum but it also has a carbon water seal on the inside and usually you will need to change this too as if you disturb the bearings it will surely leak. If you have never done this before it can be dreadfull. If your drum has bolts and a seal at the back to withdraw the inner drum and back plate out the back of the machine then you are lucky and you should be able to do the job in about two hours. If you dont have a removeable back on the drum you will have to strip the whole machine and remove the drum supports and hydraulic pistons at the bottom. All hoses and pipes and wiring attached to devices on the drum will have to come out as well as the door seal and soap dish rubber connector. Good luck.
    Apr 03, 2009 | LG Washing Machines
    Bearing noise
    You have to remove the outer tub assy from the cabinet then split the halfs, We're told the the bearings are part of the rear tub housing. You might be able to press out the bearings
    Feb 11, 2008 | Kenmore 43142 Front Load Washer
    Hotpoint WMA40 Front Load Washer Logo
    1,043 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Todd Arndt
    Todd Arndt
    puggy666
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
