Question about Sony Ericsson K320i Cellular Phone
Sound Recorder k320i
I am unable to record sound even after pressing proper options....Its just only not recording sound...pls help me out
    Brigadier General:
  • 7,752 Answers
Take the phone and have it checked first and then try reflashing the phone to see if that corrects it
Posted on Oct 15, 2008
No sound, I can record to HDD but there is no audio, why?
i think , there are some virus in ur hdd, ur audio files may be hidden. pls use smadv antivirus free apk. and explore hidden files. it will help u.
Sep 05, 2016 | Toshiba RDXV59DTKB Rd Xv59dtKB Dvd...
Recording / no soud
If there is a firmware download available you can update the firmware, that will fix the problem.
Oct 27, 2008 | GoVideo VR2940 DVD Recorder/VCR
My microphone is not working. What do I do? Trying to use Skype, but microphone want work
Hi ldlw65,
Please follow the below steps to set up your microphone properly :-
  1. Firstly check if your microphone's cable is in proper order, if it has been damaged, then it's that physical fault which stops microphone from working.
  2. Now if the wire or cable of microphone is OK, check if you have connected your microphone in the correct slot , in your motherboard , usually there is a sign of mic besides the microphone slot.
  3. Then check for the control panel's sound and audio devices option , by going in your control panel, if you open it and go in the audio tab you should see your recording device as enabled.
    If it's disabled then you need to install your audio driver's again.
  4. Now , if everything is ok till here , all you need to do is do a microphone check by going to sound recorder (start >programs>accessories >entertainment>sound recorder )in windows xp , in case you are using windows xp or any relevant software in the other operating system which records audio.
  5. Once you have the application like sound recorder try speaking on mic while you activate the record option , if you see that your sound is being recorded, then your mic is functioning properly, if it's not then you need to check if your mic is the current recording device.
  6. To check if your mic is the current recording device , all you need to do it double click on the volume icon on your task bar and you will have volume control box open , then you need to go to the options menu and choose properties.sajjad4help_2.gif
  7. After you choose properties you will have a radio button for recording , select it and you will find devices for recording , then make sure microphone is selected and click ok.sajjad4help_6.gif
  8. After you select ok , then you need to select microphone from the recording options to activate recording via your microphone.sajjad4help_7.gif
Now you should be able to use your microphone properly without any problems.
Your feedback would be appreciated.
Hope this helps ..)
May 13, 2011 | Toshiba (P000257700) Microphone
How i can recorde
Music or video ?????
If video you can install vlc player from here free:
http://www.videolan.org/vlc/
When installed click on show in the menu bar
and select advanced control now the player can record.
When click on the record button.
And it will create your video in your video map.
For music also for free you can install this recorder from here:
http://www.sound-recorder.biz/freesoundrecorder.html
Free Sound Recorder does exactly as it sounds -- it is an easy-to-use FREE software program that lets you record any sounds from your sound card and save the recording directly into MP3, WMA or WAV files.
Free Sound Recorder is a perfect audio recorder to record your own voice, music or any other sound by working directly with your sound card. It supports the record input/source from a microphone, streaming audio from the Internet, external input devices (e.g. CDs, LP, music cassettes, phone line etc.) as well as other applications like Winamp, Media Player, etc. With built-in advanced audio record engine, the recorder produces high quality recordings.
If you're looking for an application to help you for audio recording, you won't be disappointed in Free Sound Recorder! Main Features of Free Sound Recorder
bg_link_arrow.gif Allows you to record audio into MP3, WMA or WAV format directly.
bg_link_arrow.gif Allows you to pre-define audio recording qualities to help quickly set and manage recording parameters.
bg_link_arrow.gif Built-in advanced audio record engine to produce high quality recording.
bg_link_arrow.gif Allows you to preset/preview your audio recording device before starting record.
bg_link_arrow.gif Build-in WMA WAV MP3 decoder.
Hope this was helpfull
Mar 10, 2011 | Computers & Internet
Microphone not detecting sound in sound recorder
1. Right click the sound icon in the system tray
2. Click "Adjust audio properties"
3. Go to the "Voice" tab at the top
4. Ensure that a device is selected for the section "Voice Recording"--ensure the appropriate device is seleted--most likely ti will just be one option --make sure it is selected
Dec 19, 2009 | Dell Inspiron 1520 Motherboard
Din Unlock - Unable to record
You must have the unit switched to "DIGITAL" input - switch it to "ANALOG" and record that way. The "DIN UNLOCK" is when you have the lack of a proper digital signal, or a digital signal with copy protection, like you cannot make a digital copy of a digital Minidisc, etc...Does that make sense? Let me know if the "Analog" setting works for you. Good luck.
Nov 07, 2009 | Sony MDS-JE330 Mini Disc Player
My laptop microphone isnt working
Good day, Hi, to test your laptop mic, open the sound recorder. 1. if you ar using XP, goto START, All Programs, Accessories, Entertaiment, Sound Recorder. If the sound recorder loads normally, press the red button, shout as load as you can, you will see sound waves on the recorder. 2. If the sound recorder does not loads, chances are your mic isn't working properly, Load the device Driver for your mic, you can find the driver on the CD that came with your laptop, if not you may need to go to the Internet to find the MIC driver. 3. If the driver is loaded on your laptop, chances are it may be defective, you have 2 options, 1. replace the mic on your laptop, which requires you to dismantel it, get the defective mic and replace it. 2. just get an external mic. hope this may help.
Aug 02, 2009 | Computers & Internet
No sound recorder icon on my computer
ok open --double click volume icon in task bar near time , u will be seeing VOLUME CONTROL in that press OPTIONS ---> PROPERTIES ---->RECORDINGS , in that make sure microphone is checked
second after that ur micophone slider bar shd be at upper end..
pls tell if ur problem solved or not?
Jun 19, 2009 | Toshiba Satellite A135-S4527 Notebook
How to have unlimited voice record with my n70 nokia,pls help me
just enter call record setings where u wioll find an option asking u time of record where u can choose ur desired time of record
May 04, 2009 | Nokia N70 Cellular Phone
Audacity
Use Sound recorder that is included on Windows XP it gives the easiest conversion option for .WAV files.
Converting the File Properties
1. Left click Start, Programs, Accessories, Entertainment, Sound Recorder. If you
intend to do this procedure often it is recommended to drag the Sound Recorder shortcut
icon onto your Desktop for convenience.
2. In the Sound Recorder box click on File> Open
3. In the Look In field locate and select your file. Click Open.
4. The Sound Recorder box is back. Click File> Save As.
5. In the Save As box click Change…
There are all the options listed that you can change and the bit rate is one of the options.
Jul 19, 2008 | Olympus VN-3100PC Digital Voice Recorder
Sony Ericsson K320i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
