Question about Acer Computers & Internet
2 problems: 1. Is there a way to make the images on my 19 inch acer lcd monitor not appear stretched? 2. How do I get a screen resolution of 1440 x 900 (It's not one of the options in my display settings - I'm using Windows XP).
  • 21 Answers
1. The only way to avoid stretching of images is by increasing the resolution. Many 19-inch monitors with conventional (4:3) aspect ratios have 1600 x 1200 pixel resolution. The 1600 x 1200 resolution is ideal for graphic artists and those who work with photos, since it's close to the resolution of a 2-megapixel digital photo.
2. You can double check by going to the display properties - Settings- Advanced tab below the screen resolution slider, choosing the Adapter tab, click List all modes and that will settle it once and for all. If 1440 x 990 isn't listed you're likely going to have to buy a graphics card that can reproduce that resolution.
Also try and update the driver for your graphics card.
Posted on Jul 06, 2008
Image stretched widthways
Depending upon your operating system: Right click on an open area of the background screen. The goto to settings or display settings. From here you're going to want to change the display resolution or display size to match your monitor. Experiment with the different sizes until you get the one that's right for you.
May 13, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Image on Monitor is slightly blurry
Try reducing the screen resolution to 1/2 of what it is now!
Jan 20, 2010 | Acer AL1916W 19" LCD Monitor
Plugged in a new 23 inch LG LCD Monitor and cannot get picture
In additio to the fine help given by Mister.
If you have a DVI output on your computer get the cable for that and this will greatly increase the quality of your display.
Your graphics card should be able to autodetect a DVI monitor and suggest the best display type.
Sep 16, 2009 | Computers & Internet
AOC 917sw 19 inch monitor resolution issue (same as above)
Have you try the following resolution values:
1280 x 768
Usually its the standard for widescreen view
Please don't forget to rate if answer is useful
Jun 18, 2009 | AOC 917Sw 19" LCD Monitor
Monitor stretches the images. How is it possible?
you might just need to touch the resolution or else check if the monitor has right settings from its inbuilt menu.
Mar 17, 2009 | iiyama ProLite E481S-B 19" LCD Monitor
Acer P193W monitor stretched image
What service pack of windows xp are you running? Also, do you have your old monitor, if so, then plug it in and see if the same problem occurs. If not , go under the settings for your graphics card (not windows display options) and see if there can be a correction made to the settings for your monitor. Also, try going to and updating your computer (it's free) and you'll probably get the required driver to fix the problem from them. Check under your control panel and see if you have automatic updates turned on, if so you may want to limit what updates are to be installed by allowing updates but you choose which one's to install. Hope I could help. My e-mail .
Jan 04, 2009 | Acer X193W LCD Monitor
Entire image shifted
Press the Select/Auto button. The monitor will then automatically adjust to match the incoming signal and will save that setting in the internal memory of the monitor.
Nov 06, 2008 | Hyundai L90D+ 19" LCD Monitor
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
After any game, and go back to XP, my monitor go like 8 bit color,have to power down and up
Try useing a different resolution. The native resolution should probable be 1280 x 1024. Try updateing the video drivers.
Nov 23, 2007 | Acer AL1916W 19" LCD Monitor
Oblong pictures
The issue here is that you have a low resolution picture and a high resolution display. Windows is "stretching" the smaller, low resolution picture so that it will fit across the larger area, thus distorting it. Right click on the desktop and select properties. Go to the Desktop tab. There should be an item there for position. Is it set to Stretch? If it is, then this is causing the problem. Set it to center, and it should appear fine. If you want to keep this from happening: 1) User higher resolution pictures. 2) Turn down the resolution on your screen (this can be done from the Settings tab of display properties).
Oct 01, 2006 | Samsung SyncMaster 940BE 19" LCD Monitor
Computers & Internet Logo
183 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
