Thereis a little clip that holds focus screen up in mirror box. You need to use tweezers to release and pull screen. Keep dustless or youll see it all. Katzeye?
thereis a lot of possibility check vacuum lines,camshaft sensor ,crank sensor,intake air control valve .dirty mafs /air filter,bad fuel pump,bad ignition system and so on
hi..gud day ur magic chef is smaller than maytag? do u think the space of ur old unit is enought to fit the new one? 5inc are different.u waste ur money.
i'm sorry to say It's most likely broken. I think the LCD screen is going. Try calling up Samsung to see if they can fix it or repair it for cheap. Good Luck.
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
The deflection circuit is most likley bad. You need a service center to repair . If you can TEST THE BIG FAT TRANSISTORS AND CHANGE OUT IF BAD, THEN YOU CAN FIX IT. They are usually on a big metal finned heatsink ...
The convergence adjustment on the TV set are for the center adjustments ONLY. if you cannot get them in or they are way out, then you have a convergence IC problem. Dont feel bad though as it happens to every rear projection set ever made. Good Luck
