Question about Lands Phones
Need to find buyer for Praxon PDX system (complete)
Hello -
I have a Praxon telephone system. Complete and (last I knew) fully functional. I would like to sell it as a complete system however I would also entertain offers for individual boards if I cannot sell the system in one piece. Is this something you would be interested in? If not, would you know where I can locate a customer for this system?
Thank you very much for your time and consideration.
Mark Titterington
RI Trading Co
SOURCE: GE duo 21828 cordless telephone english user manual
Press down key until the handset menu appears and press "INT/OK" key
Press up or down arrow key to select the submenu "Resgister" and press "INT/OK" key
Handset display shows "SEARCHING".
Press and hold "page" key on the base station more than 4 seconds until acknowledgment signal is heard
Enter the PIN (default setting = 0000) and press "INT/OK" key
on the Handset
If the input PIN is correct the registration procedure will be completed with a confirm tone.
After a connection is established the name and number of the handset appear in the display
Note : The base will be ready for registration for 10 minutes when the page key is pressed and held for more than 4 seconds.
Please let me know how these phones have performed, are you happy with them. Thanks
Posted on Jun 28, 2008
How to program name and extension
Press PROGRAM ** (then system password default is 1234) Use volume key to shoe extension name in display Use ENTER and ARROW keys and ALPHA NUMERICAL entry to change Press STORE to complete
Nov 09, 2012 | Panasonic BTS Panasonic KX-T7730 White...
On the screen of the phone says not registered and wont allow me to make phone calls or recieve
Please try the following procedure to register the handset:
  1. Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
Mar 05, 2011 | Vtech DECT 6.0 Digital Cordless Phone
How do I store telephone numbers
Welcome to FixYa, the best online community for tech related issues.
Please elaborate your problem providing us with more details and the complete make and model number of the product.
Thanks for using FixYa.
Feb 22, 2011 | Uniden Lands Phones
Need to replace new batteries & charger
When I went for batteries for MY KX-TG5632, I found they were $20.00 each. I also found I could purchase an entirely new telephone system (base and 4 satellites and chargers, five complete wireless telephones) for just over $95.00. So, I dumped my otherwise perfectly good, but old, telephones and bought the new system.
If you want to get new chargers and batteries, www.batteries.com is a good place to start ... You can go to many of the Big Box stores, Radio Shack has a good selection and there are many other fine retailers where you can purchase these batteries, including several FixYa.com advertisers.
Thank you for your interest in this web site.
Feb 02, 2011 | Panasonic KX-TG5632 Phone
Vtech 6.0 deregister
Getting startedReplace a handsetIf you want to replace a handset or reassign the designated handset numberof a registered handset, you must deregister all the handsets and thenindividually register each handset.To make deregistration easier, read all of the instructions on this page beforeyou begin. To deregister all handsets:Press and hold FIND HANDSET on the telephone base for about 101.seconds (until the IN USE light on the telephone base turns on and starts toflash), then release FIND HANDSET.Press and release FIND HANDSET again. You must press FIND HANDSET2.while the IN USE light is still flashing. The IN USE light flashes forapproximately seven seconds.All system handsets show CONNECTING... The deregistration process3.takes about 10 seconds to complete. All handsets show NOT REGISTEREDwhen the deregistration completes.If deregistration fails, you might need to reset the telephone and try again.To reset:1.Pick up the registered handset and then press talk/flash.Press OFF/CLEAR and place the handset back in the telephone base.2.-OR-1.Unplug the power from the telephone base, then plug it back in.You cannot deregister a handset if any system handset is in use.
May 29, 2010 | Vtech Cordless 6041 Phone
Load default Delta file message
Problem My handset displays either LOAD DELTA FILE or LOAD DEFAULT DELTA FILE. What should I do?
Solution(s) Tip 1 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
Nov 16, 2009 | AT&T 650530003417 Cordless Phone
NO CALLER ID 25881EE3-A
The GE Cordless Phonemag-glass_10x10.gif brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems.
    Before You Start
  1. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  2. Phone Setup
  3. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  4. The Basics
  5. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 14, 2009 | Uniden Cordless Phone
I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
you don't hear a dial tone
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
Sep 07, 2009 | Uniden DECT 6.0 Cordless Telephone...
Trying to get "Forwarding a Call" to work
72bec56.png Wow, check this out. Here's the complete set of instructions for call forwarding to an outside line. There are programming considerations that need to be done.
Carl
Jun 26, 2009 | Panasonic KX-T7730 Corded Phone
Cordless won't connect
check the jack with a different phone that you know works.
Feb 01, 2008 | AT&T E5908 Phone
Lands Phones Logo
67 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
