Question about Nokia 1110i Cellular Phone
My nokia 1110i is not going to switched on instantly
After i switched off my mobile(working o.k.)to insert new sim card and then try to switched on but it can't switched on instantly
i think it should be a software problem
what should i do?
  • naveenkumarv Mar 12, 2009
    software cxomplaint
That's software complainyt sure
Posted on Mar 12, 2009
    Sergeant:
  • 234 Answers
Yes! software only problem! install new software to your mobile!
Posted on Jul 06, 2008
STEPS ON HOW TO UNLOCK NOKIA 1110I
Do you have unlock codes to unlock your mobile?? if so no problem you can follow the instruction and can get your nokia 1110i unlocked..if you dont have unlock code then try Simpleunlocking to get unlock code for your mobile and get it unlocked..Here is the instruction..
Warning : Do not enter any wrong unlock codes on your Nokia 1110i mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1110i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 1110i without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1110i.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1110i would then display the message "SIM Restriction Off" and will be unlocked!
Dec 07, 2011 | Nokia 1110 Cellular Phone
Nokia 1110i how to openline using twister bow
I don't know about that Twister Box Hardware unlock ...It's not easy it's very risk also,but Unlock code Unlock or Openline from Network Lock is simple,You can get the Unlock code from here Theunlockspot.com/nokia/rs10wp8/ and Unlock it step by step follow the instructions below:
Nokia 1110i Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 1110i mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1110i mobile phone, your phone may get hard locked and sometimes become unusable.
Aug 09, 2011 | Computers & Internet
My phone imei no359573015932083 . plz sent security code for my mobil(1110i) .
Okay, the unlock code for your Nokia 1110i can depend on what service provider you have, here is the solution:
Unlock Codes
#pw+756660772303751+1#
#pw+329386440660272+7#
Instruction
Step 1: Type the codes generated similar to #pw+CODE+n# (with SIM card in the phone)
To get "p" press the "*" key 3 times
To get "w" press the "*" key 4 times
To get "+" press the "*" key 2 times
The 'CODE' must be 15 digits and 'n' shoud be 1 and if
didn't work use 7.
Step 2: Your phone is then unlocked!
REMEMBER: You only have 3-5 tries in whith to enter the
codes. After that, only a cable solution will help you!
This is the solution but it may vary depending on whether you have T-Mobile, AT&T, etc.
So, if this doesnt work, go to this set and you can generate your unlock code free!! Here you go:
http://nokia.unlock4all.com/1110.php
Good luck!!
EJ
Mar 11, 2011 | Nokia 1110i Cellular Phone
I get insert sim card error message whenever i insert the sim card in nokia 1110i
Hi, there may be some static on the sim that is affecting it. Rub it on your trousers before re-inserting to the phone, this can sometimes help. Have you tried the sim in another phone, it may be the sim thats at fault??
If this helps please rate me
Jul 23, 2010 | Nokia 1110 Cellular Phone
My Nokia N72 is working only in offline mode. I therefore cannot make or receive calls. When I try to switch to general mode, it says I must insert a sim card whereas the sim card is inserted. Will you...
This problem is called the 'insert sim' problem, there are several possibilities but first of all clean the sim card and the sim card interface on your phone. Next try it with another sim card. If this doesn't solve the problem, you need to go to the mobile repairing shop to get it serviced, or if you have idea in repairing mobile you can refer to this site on how to do jumper tips and tricks for this problem..http://sephonetechnology.blogspot.com/2009/08/nokia-n70-sim-ic-jumper.html Good luck.. and please...-:)
May 04, 2010 | Nokia N72 Cellular Phone
Sim card not registered
THERE IS A SOLUTION
if u cant even see the battery charging you have two possible errors:
1. the display
2.the mainboard
the easiest way to test this if u have an another phone to cross the displays to see if the problem still exists.
If the problem still exists your mainboard is damaged.
Mar 15, 2010 | Nokia 1110i Cellular Phone
Nokia 1110i says sim card not deteted even after sim card is inserted. Gives same message even after other simcards are inserted
It when your sim tray is been damaged thats when you experience problems like that.
Your sim card tray where you put your sim card is faulty,thats why your sim cards can not be accessed.
So you need to take it to a repairer to change the sim tray.
It needs to be changed
Jan 20, 2010 | Nokia 1100
Fixing Nokia 1110i phone off Demo mode
the only reason it says demo mode is because you dont have a sim card in it
Feb 09, 2008 | Nokia 1110i Cellular Phone
"Insert SIM card."
its the contact of the simcard to the leads. try putting a thin piece of paper over the sim so that there would be pressure on the sim. as always, think of the contact.
Feb 07, 2008 | Nokia 1110i Cellular Phone
Insert sim card
Either the sim card is not inserted or the connections from the sim card to the phones electronics are faulty or the sim card itself is dead. Try another sim card to see if that works. Cleaning the sim cards contacts with a q-tip and some alcohol could also help
Jan 17, 2008 | Nokia 1110i Cellular Phone
Nokia 1110i Cellular Phone Logo
53 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
