Question about Diamond Multimedia RADEON 9250 PCI 128MB Graphic Card
System failure sir often my system is restarting its own after restarting it is showing that system failure please give me a solution sd/- Riju Mohan
    Sergeant:
  • 287 Answers
Possible causes and things to check
  1. check that your RAM is installed correctly - remove and install again ensuring power is disconnected first
  2. check that CPU fan and video card fan both work OK and clear dust from the heat sinks
  3. bad video driver - load new driver for your card from HERE - select your OS, then Radeon, then 9250 and press GO.
Post back results for further tips if required.
Posted on Jul 06, 2008
Toner control system failure
try a different toner cartridge. sounds defective cartridge'
Aug 04, 2015 | Xerox Office Equipment & Supplies
SYSTEM SHOW OPERATING SYSTEM NOT FOUND ONCE A DAY
sounds like a harddrive giving up or just need to reinstall windows
Nov 20, 2008 | Computers & Internet
My phone getting restarted
h plz go to the nokia priority or the showroom with ur bill, and ask them to update ur software, u can check ur software version by pressing these keys *#0000#
Nov 04, 2008 | Nokia 3110 Cellular Phone
Ram when i upgrade 128 sdram to 256 sdram in intel 845glly it shows spd
It is not seieng the ram, try swapping the ram around or leave out the 128MB, just put in 256MB, if no boot then the ram is not compatible or faulty, not all ram sticks work in all motherboards.
Sep 08, 2008 | Intel D845GLLY Motherboard
Sound device problem
you have doesn't gave me the description about your sound card. any way at please install your sound driver and direct-x 8.0 or supportable above then restart.
Aug 04, 2008 | Microsoft Windows XP Professional
Desktop is blank
Shut your off. Wait 30 seconds. Boot the computer up into safe mode by pressing f8 before the Windows screen appears. Select Safe Mode and press enter. Once the desktop appears, restart your computer the normal way.
If it continues you should reinstall your operating system to fix the problem.
Aug 02, 2008 | Microsoft Windows 98 for PC
SYSTEM IS RESTARTING UNEXPECTEDLY
Hello Rijumohan.
You havnt specified that is your system showing the desktop screen or it restart itself at the begining of the BIOS Message.
if you are able to see the desktop screen then:
The first thing you should suspect about the Viruses.
Because your virus leads to your very slow as well as restarts itself without awaring you. It is caused by Worm and Trojon viruses. For making sure that ur system is suffering from virus go to tools in menu bar and check for folder. if the folder option appears to you then it is okay. again try to go to Task manager by right clicking on the tasl bar. If the task manager is also showing then you are not affected of viruses. Run any antivirus setup if you are suspected about viruses on your system
another reasion could be, missing of attrib.bat or command.com file from ur system.
for these reasion Repair or format ur active drive.
OR If your system restart itself at the begining of the BIOS Message:
1. Then your RAM goes bad.
2. You havenot installed ur Expansion card properly.
3. If you have attached to hard disc then check for jumper settings. (or if you have attached two hard disc, one is SATA and another is PATA)
do the remedies for the same
(Gimme ur acknowledge by rating me)
Romy
Does it give any error message before restarting?
Aug 01, 2008 | Microsoft Windows 98 for PC
NOKIA 3110C DOES'NT WORK WITH MEMORY CARD
Dear sir,
I have Nokia 3110c mobile.When i was insert memory card(micro sd 1gp),it was continuously restarting.So please give some solution.
Jul 16, 2008 | Nokia 3110 Cellular Phone
BAD SECTORS
Your hard drive is divided into bits called sectors. When these sectors start to go bad, that means that the computer cannot read or write any data on those sectors. You cannot remove bad sectors and once you start seeing bad sectors it is a sign that your hard drive is about to crash permanently so you need to replace your hard drive and make sure you back up all ofyour important data immediately.
Jul 06, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Diamond Multimedia Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Jason Harris
Jason Harris
Are you a Diamond Multimedia Computer and Internet Expert? Answer questions, earn points and help others
