Question about Nokia N95 Cellular Phone
Update problem i tried to update my n95 to new firmware 21.... inthe middle of installing, it's stopped and it ask me to recovery by removing battery and charger. after i did, the phone won't turn onand i can only see nokia in the screen without light. it cannot recover anymore. any can help plss
Dear nokia bussions marketing....delhi
Posted on Jul 06, 2008
My N95 kept rebooting itself so i looked around on the net and found that i need to install new firmware. I downloaded nokia software updater and it starting downloading the upgrade. However about 14mins...
You should try to install NOKIA SOFTWARE UPDATE to ur phone to install the new firmware .It is just software problem not any big to worry.You can go to any nokia center to reinstall the firmware and got ur phone A1.
Dec 05, 2009 | Nokia N95 Cellular Phone
Audio failure
Maybe you should try updating the firmware of the product through nokia pc suite. Most latest firmware for N95 is V 21.0.016.
Try it. Most problems with the N95 as solved by updating the firmware.
Sep 20, 2008 | Nokia N95 Cellular Phone
HELP ! Frozen Nokia N95
try to push and hold together buttons * ,3 and green handset then press power ( still holding buttons) .
If it's not work you must do a manual software upgrade in service centre or someone who have special hardware for that. if you need that you can contact me at pluciorx@wp.eu
Sep 13, 2008 | Nokia N95 Cellular Phone
N95 startup problem
do not consult a technicition i have had this problem and solved it for my friend, you were trying to update your n95 firmware using nokia software updater then it said please unplug and remove battery you should never touch a mobile during an update... anyway to fix it your n95 thinks its still in a middle of the update so charge your phone for 10 minutes (DONT TURN ON) then connect up to the computer via usb to your n95 then open up software updater and press start update it it says could not find deivce keep retrying it took me 20 minutes but could last up to 1 hour then it willl recognise the phone and continue update and turn itself back on only problem is that your phone will be reset but you still keep your memory card data
post back asap dale goodwin
Jul 22, 2008 | Nokia N95 Cellular Phone
My nokia n95 keeps turning itself off
my nokia n95 keeps turning of . every time i try to turn it on it turns on and keep restarting till the battery dies.. any solutin for it please.
Jul 05, 2008 | Cell Phones
Nokia n95
Try formatting your phone. Turn it off. Then hold the following keys WHILE it's turning back on: (3 + * + green call key). Don't let go till it asks you about your location. Be aware that it will delete everything saved in your phone memory. Let me know how it goes. :)
Jun 26, 2008 | Nokia N95 Cellular Phone
Constant Restart and problems updating firmware
Jun 25, 2008 | Nokia N95 Cellular Phone
N95 RESTART AND RESTART AND STOP FUNCTION
Did you try taking the battery out for 10 minutes? Did you try performing a master reset?
Jun 02, 2008 | Nokia N95 Cellular Phone
Firmware Problem
I had this problem as well and found help. I tried the suggestions below and the problem was fixed! What you can try is this: Open up Control Panel Click on Performance and Maintenance Click on System Click on Hardware tab Click on Device Manager button If you see a Yellow Exclamation mark beside something that looks like the DJ then double click on that. If you see something that says to Update the driver then do so. If it asks to checked Windows Update, choose this option!! If this fails then delete it from your computer by pressing the Del key then clicking OK. Restart the computer, connect your DJ and see if it works properly. If not, open up Device Manager again. This time remove ALL your USB ports, everything under Universal Serial Bus controllers. Restart your computer, let it reinstall your USB devices, connect your DJ with its done, hope it works... If not, open up Add/Remove Programs Click on Show Updates box in the top middle if your running Service Pack 2 Scroll all the way down until you see Windows Media Player 10. If more than one WMP 10 item is showing then remove those first. After your PC restarts remove WMP10. If removed successfully then your computer will now have WMP9 installed. Open up WMP9, click on Help, click on Check for Player Upgrade. WMP10 should be displayed. Let it update... After your computer restarts, install the Windows Media Format 9.5 Runtime from this sticky Restart your computer, connect your DJ and hope it works....... Or you can just take it to another computer running Windows XP and WMP10 and if it recognizes correctly then put back a v1 firmware, I recommend 1.02.01. Download it from this FAQ Hope this helps you as much as it helped me.
Jan 22, 2007 | Dell Pocket DJ MP3 Player
Nokia N95 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
