Question about Hoover Dryers
I have a Hoover 5030d & its making a noise as the barrell turns. If spun manually it sounds a bit like a bearing. Is it easy to change a bearing on a Hoover 5030d?
    Problem Solver:
  • 11 Answers
It sounds like the engine shaft bearing. Fairly simple to fix or replace with the correct tools and know how.
Be sure to take photo's of the motor, tension arm, and any wiring.
You'll need pliers to remove the clamp from the fan, then remove the belt from the motor and make sure that's were the problem is before going any further.
Posted on Dec 29, 2010
Have a 6kg hoover tumble dryer making noises when on sounds like something trappped under drum
it sounds like your bearing are gone you can buy a bearing kit its not an easy job but if your a handy man or woman it can be done
Jul 29, 2014 | Hoover VHC391 T-80 Dryer
Hi. My dyson dc14 wand works great then all of a sudden if something too big or even just the carpet it makes a sucking noise & the purple round bit in the actual Hoover makes a funny noise & then...
Sounds like a blockage. I have a DC14 and I have never had this problem. You can easily remove the wand from the flexible hose and the flexible hose from the machine to check for a blockage. Don't allow paper or larger items to go into the machine, especially the wand, pick it up by hand first. Find the online manual here: http://www.analogstereo.com/dyson_vacuum_owners_manual.htm
May 03, 2013 | Vacuums
The washeers drum sounds a bit nosy I think smething might be stuck inside the inner drum. How do I get to check the inner drum?
the inside of the drum makes a clicking sound, and I located the noise at the back of the drum and the noise seem's to be in the central part where the bearings is located.
Jun 29, 2010 | Hoover Nextra HNWL 3166 Front Load Washer...
2005 crf250r trans oil and funny noise
The water pump seal is maybe gone.This would allow water into the trans.Get it checked and also that the bearing hasn,t spun in its location.This may cause the color change.Being a grey color,it may indicate aluminium in the oil.This may be the spun bearing turning in the housing.With what you wrote,I would get these things looked at.I hope this helps you
Nov 03, 2009 | 2005 Honda CRF 250 X
Hoover makes terrible screaching sound when using upright.
It's most likely the bushings/bearings in the beater bar (roller). The beater bar cover is fairly easy to remove -- take it off and investigate. Could be that the roller only needs lubricating on the ends. Also, check the belt to see if it's intact or damaged.
Clean area thoroughly.
If this is not the problem, please, let me know.
Charlie
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
2004 grand prix roaring noise
It really sounds like a wheel bearing to me, If you drive down a straight smooth road and gently rock the steering wheel back and forth, you can sometimes tell which side it is by the way the car loads the front wheels. I believe this bearing can be purchased as hub and bearing assembly so it is fairly easy to replace but the part is pricey. Remove the wheel, brake caliper and rotor, look through the hub flange access holes and undo the mounting bolts and pull the bearing assembly out of the knuckle.
Mar 11, 2009 | 2004 Pontiac Grand Prix
Eureka Boss Capture - bagless upright - green
HI
are you sure its the height adjuster?
More likely to be the bearings in the brush.
Rob
Feb 14, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Belt keeps coming off hoover nextra hnl 3416
It sounds like the bearing.
It`s quite a big stripdown job.
If you are good at DIY then you should be able to do it.
Just make sure the drum isn`t damaged where the bearing fits.
Feb 02, 2009 | Hoover Washing Machines
Really loud noise.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40860&thid=810370
Really loud noise.
Posted by Theresa626 on July 20, 2008
The belt inside my Hoover broke and so we replaced it. But when we did, it now makes an extremely loud noise when turned on. We think it’s the roller to the vacuum because it doesn't make a noise when the roller is not in there. The roller sounds like its hitting something. However, we have pushed and pulled and done everything and all seems to be right. Everything is clicked in and the belt is on correctly and we've followed the manual. How can I fix this problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that it is a bad brushroll and could need new bearings or a complete new brushroll depending on if id is metal word or plastic. Some brushrolls are rebuildable and some are not, you can check your owner’s manual to see if it is or is not; or it could be the start of a broken fan blade or bearing in the motor section. But that is the only thing that I can think of that might be wrong. Feel free to contact your local vacuum cleaner dealer in your area or you can also contact the Hoover website or cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hoover U5018-900 Bagged Upright Vacuum
Dryers Logo
638 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
