Question about Karcher 2500 PSI Pressure Washer
Water runs out of radiator and out exhaust when engine is running it,s a vs commodore engine
  • 33 Answers
Blown head gasket. compression is forcing water back into cooling system
Posted on Apr 21, 2009
I got a vs commodore got no power to fuel pump change fuses and relays and still nothing
Please be aware that the fuel pump only runs if the engine is cranking over to start or of course when it is running.
Nov 22, 2016 | Cars & Trucks
10 cd stacker in vs holden caprice. The cartridge is jammed in the stacker . How do you get it out and get it running again?
The guys on the Just Commodores Forum may be able to help you with that. Here is the link..................
Forum VR VS Holden Commodore 1993 1997
Jan 04, 2016 | Holden Cars & Trucks
The engine is 4d33, now there is a heavy mixing of oil in the engine but no oil found in the radiator, when ur pouring water in the radiator it's not getting full whilst it is running
Blown Head Gasket Symptoms:
  • Coolant leaking externally from bellow the exhaust manifold.
  • White smoke from the exhaust pipe.
  • Overheating engine.
  • Bubbles in the radiator or coolant overflow tank.
  • White milky oil.
  • Significant loss of coolant with no visible leaks.
Apr 20, 2015 | Cars & Trucks
Coolant commodore
Don't mix coolants brands. best to drain and flush the radiator and block don't forget to flush the heater also. refill with the best coolant you can find. run engine to working temp and top up radiator . don't forget to flush the overflow tank.
Jul 04, 2014 | 2006 Holden Commodore SS
95 ford probe car runs ok but blows whitish blue smoke as accelerate
That is probably the head gasket leaking. White smoke is from antifreeze going through the exhaust. The engine compression is pushing the water out of the radiator.
Nov 27, 2013 | 1995 Ford Probe
Vs ecotec vs commodore engine light comes on after driving
I have no dash lights so at night I can only use the speed set to let me know what speed im doing how do I fix them in 95 vs commodore
Sep 16, 2012 | Lexus GS 300 Cars & Trucks
Radiater fluid coming from behaind balancer Model V6 VS Commodore New Radiater instaled and not coming from there any Ideas???
check your entire cooling system for leaks including water pump, thermostat, radiator hoses, even your coolant reservoir. leaks are rough man sorry for your frustration.
Mar 27, 2012 | Holden Ute Cars & Trucks
I have a 2002 ford ranger that runs normal while engine is running but gets hot when i shut off engine
SOUND LIKE ENGINE OVERHEATING.USE A INFRA THERMOMETER ENGINE TEMPERATURE SHOULD NOT EXCEED 104 CELSIUS WHICH IS 220 DEGREES IF ENGINE EMPERATURE GOING OVER 230. THERMOSTAT STICKING PARTIALLY CLOSED,WATER PUMP FAILING CHECK WEEP HOLE IF LEAKING REPLACE WATER PUMP.FLUSH RADIATOR ,HEATER CORE, AND ENGINE BLOCK. MAKE SURE YOU HAVE 50 / 50 ANTI FREEZE AND WATER.MAKE SURE ENGINE EXHAUST NOT STOPPED UP BECAUSE EXHAUST SYSTEM ALSO TAKE HEAT AWAY FROM ENGINE.
Aug 11, 2011 | Ford Ranger Cars & Trucks
What would cause my 2002 zx2 to overheat ?
Faulty thermostat, failed water pump, inoperable radiator fan, low coolant due to leak, faulty radiator cap, leaking head gasket, low oil, major exhaust leak near front, exhaust blockage, or incorrect ignition timing. If there is crust around radiator cap, cap is leaking. How long does it take to overheat? If it runs smoothly when cool, and all fluids are at correct levels, you can rule our head gasket, radiator cap, and ignition timing. If it overheats very quickly and fluids are correct, it is probably thermostat or water pump. If it seems to do better at higher speeds, it is probably radiator fan. You can check this by allowing vehicle to run in Park with hood open. Monitor engine temp on dash. When it is at or slightly above normal running temp, radiator fan should come on. Also note exhaust sound. If it seems loud and overheats gradually, you may have a leak before the converter. If the exhaust sounds quiet, but exhaust manifold is getting extremely hot (may glow red), there is probably a blockage. There will also be OK starting and idle but poor acceleration if exhaust is partly blocked.
Nov 25, 2009 | 2002 Ford ZX2
1fz-fe engine 80series using water unable to find leak small leak also runs rough especially at idle changed spark plugs and leads mechanic unable to find leak
you may have a blown head gasket ... water can get into a cylinder .. that would cause the rough running and the water goes out the exhaust .. thats why you cant find the leak .. often as the engine is running you will see bubbles in the radiator .. thats exhaust gas getting into the water jacket ... you may also see a little steam in the exhaust (white smoke) ..
Aug 18, 2009 | 1997 Toyota Land Cruiser
Karcher 2500 PSI Pressure Washer Logo
124 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
