Question about Cameras
My dane-elec sd memory card doesn't work. my computer and camera knows its there but says there's an error and can't read it. i need pictures off this memory card, how do i do it?
  • 36 Answers
SOURCE: Memory Card Error
I am assuming that the camera continues to work fine with other cards, so the problem is only with the card, not with the camera.
To try to retrieve pictures, get yourself a USB SD card reader&writer (under $10 on eBay), plug it into your PC, and see if the files are readable that way.
If the files are readable, find the folder with JPG files, and simply move them to computer.
If the computer starts freezing every few seconds while you are accessing the card, or the move process is dealing with one file for a very long time (over 10 minutes), the card has physical problems, and there is a chance that things may not be recovered. Try moving each file separately. I did a quick search for you: "recover sd card files" - I found a few shareware utilities that would try to recover corrupted files, starting with "Card Recovery 3.50".
Once you are done with the recovery, determine if the card is usable in the future. Format the card using the camera (look for the option in Menu), take it out and use USB card reader to fill up the card with any junk from you computer, and then try to copy it from the card again onto your computer (create and use a junk folder). If this fails, look for a way for way to exchange the card under warranty, if you have any. Otherwise, the card may not be compatible with the camera (although unlikely). Test it by taking lots of test video and test pictures just to fill up the card, and try to read it. If everything is fine, and you want to take the risk, the problem may be a one time issue and will never happen again. Otherwise, use the card for something else.
Posted on Dec 27, 2007
  • 36 Answers
Use USB card reader&writer to retrieve the pictures directly from the card.
Posted on Dec 28, 2007
Nick Spirov
  • 35 Answers
SOURCE: sd memory card not read by computer
Reformat the card from the camera. You didn't specify camera model but every digital camera has a menu to format media.
If you don't succeed try to connect your camera to the computer and read the photos.
If that doesn't succeed either take your camera to service.
Posted on Jan 16, 2008
Sounds like the camera does not support SDHC. Check manual to see if this camera supports high capacity SD cards.
Posted on Mar 31, 2008
  • 5 Answers
SOURCE: sd card error on canon powershot s3
I have had a similar error which turned out to be a corrupted memory card. It was replaced under warranty with no questions asked. Causes may be static electricity discharge or a high humidity/temperature combination. Either way get a new card.
Posted on Jul 31, 2008
Took pictures with m dane-elec 8gb then it told e i need to format.will i lose all my pictures
Yes, formatting removes all the data. However, the photos might be on the camera's internal memory and not the SD card.
If possible, connect the camera to a computer and copy the photos onto the computer, then you can safely format the SD card.
If you cannot connect the camera to a computer, you will need to take out the SD, and verify that the pictures are still on the camera. If the photos are still on the camera, the photos are on the internal memory, in which case you can format the SD card as fat32 on your computer, and reinsert the card into the camera. If the photos are not on your camera after removing the SD card, then the pictures are on the SD card and you will need to have someone assist you further in extracting the photos.
Oct 10, 2014 | Computers & Internet
Will a 32 kg dane-elec memory card work with a Kodak easyshare P850?
No. The P850 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
May 22, 2014 | Kodak EasyShare Z740 Digital Camera
Memory Card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 19, 2012 | Nikon COOLPIX S230 Digital Camera
Have a 2008 dell xps-1 with a built in card reader. Running windows vista. The system used to read the card and download automaticly now it doesn't ? the card is a 2gb sd from dane-elec. It works on all of...
It's not unusual for Windows updates to mess up the registry and cause problems with the card reader slot. The easiest solution is to get an inexpensive card reader that plugs into a USB port on your computer. They always work. typrice_125.jpg
Feb 14, 2011 | Canon Cameras
My Dane Elec 2GB SD card won't communicate with my laptop properly - I've been using it with the Jazz T20 camcorder to make a film for my work. When I put the card into the reader (both an external one and...
It might be how the sd card is formatted. Sometimes the computer will not recognize a card formatted with a camera and therefor not be able to read it. I would recommend connecting the camera to your computer and copy the images off using the camera. If the camera is no longer working try buying a used one off ebay to recover your pictures.
Oct 18, 2017 | Dane-Elec DaneElec 1GB Dog Tag External...
Memory card error
The memory card could be too big. Some camera's can only use a certain size memory card. You will have to check your manual to see what the specifications for your memory cards. Hope this helps.
Jul 16, 2009 | Canon PowerShot A620 Digital Camera
I have a new 2 gb dane-elec memory card and when i turn on my camera it says the memorty card is full and when i try formatting it it says filesys error e00100
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 22, 2009 | Kodak EasyShare C330 Digital Camera
Write protected memory card..sd card
There should be a little switch on your memory card reader, if it is facing down, your card is locked. Push it up and then you should be ready to go. :)
Jul 07, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Cameras Logo
265 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
