Question about Radio Shack Pro-2096 Base Scanner
Programming I can't import the complete frequency information from Radio Referefence using the Win 96 program. My radio is partially programmed already. Do I need to delete that programming? I have checked multiple sources but no one can provide me with a solution. I hope you can be of assistance. Thanks
  • 211 Answers
No..you do not have to delete that programming. You can download the scanner using Win96 and then add or delete talkgroups and frequency data in Win96. Once this is complete, just upload it back to your scanner.
Word to the wise..you may want to save the results of your scanner download BEFORE modifying it. That way you can reload it if you make any mistakes while updating it.
Posted on Dec 07, 2008
Hi I have a vertex vx2100 radio and I need to know if I can use it as a police radio scanner
Yes. The Vertex VX2100 is a VHF radio which can be programmed to frequencies between 134-174 MHz. You would need to program in the frequencies you are wanting to scan as receive only (no transmit) into the 8 channels of the radio. You would need to acquire the frequencies you need, as well as programming equipment, or take the radio to a dealer for programming.
Best regards.
Mar 31, 2014 | Vertex Radio Communications
I have moved to a new area how do I reprogram my scanner to receive local bands
The best programming instructions for your scanner are found in the owners manual which you can download and print, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and trunking systems in your new area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 06, 2010 | Radio Shack Pro-96 Scanner
I own Motorola GP300 2 way radio.I need some device for changing frequencies as I needed.What equipments or any softwares to complete my need and their prices?
to change the frequency of your radio,you need programming cable/programming sofware,but this is only for authorized Motorola dealers,other options go to your nearest motorola dealer,along with your licensed frequency ,they'll program it,thank you
jack
Dec 02, 2010 | Motorola GP300 Compatible 2 Way Radio...
I need to rebanc my pro 96 and bought the programming cable and driver software item 20-047 (or 200-0047) and trying to find the driver for my computer and the users manual; neither of whic are on the cd....
Radio Shack no longer sells the frequency software for this scanner. the drivers for your computer are on the cds you have so hold on to them they also are no longer available. radioreference.com may have the software for programming
Jul 16, 2010 | Radio Shack Pro-96 Scanner
Error message when trying to enter frequency codes into the Radio Shack Pro-433... How do I enter the frequency codes I have into this scanner?
The error message almost always means that you have either entered a frequency that's out of your scanner's tuning range, or that you've neglected to enter a decimal point in the frequency. Check your operating manual to verify that the frequencies you're programming are within the unit's tuning range. If you don't already have the manual, you can download/print it here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000433_PM_EN.pdf
You can also find a wealth of useful scanning information, including a database of active frequencies in your area, by visiting:
Bill B
Jul 04, 2010 | Radio Shack Pro-96 Scanner
Would like to add a frequency to a Radio Shack
Absolutely. Just find either an empty channel or one that you want to delete - and program the new frequency. Doing so will not "mess up" any of the other programming.
For a comprehensive database of active frequencies in your area, visit:
Bill B
Apr 06, 2010 | Radio Shack Pro-96 Scanner
Manual Programming of the Uniden BC95XLTB
1. The scanner automatically selects the band, you just program the frequency.
2. Your scanner does not have the traditional channel/frequency layout that you may be used to. Rather, it uses a system called DYNAMICALLY ALLOCATED CHANNEL MEMORY, which organizes frequencies into groups and systems, and enables the scanner to cover a wide variety of conventional and trunked radio systems.
The manual for the scanner goes into detail on the various systems and programming methods, and you can download/print the full manual here:
http://www.uniden.com/pdf/BC246Tom.pdf
If it seems a bit overwhelming you might want to join a scanner group on line or in your area and draw on their experiences with the 246. You can also pick up a lot of useful information on the scanner, and access a comprehensive database of active frequencies/systems in your area by joining
To simplify the programming process, you can join the Radio Referenc group and purchase programming software from BuTel (http://www.butel.nl/) Their program for the BC246T will allow you to access the RadioReference database, select what you want to monitor, and import/program the information to your scanner.
Sorry, but the days of the Bearcat III with it's manually selectable bands and 8 "rocks" are gone, and today's complex radio systems require complicated scanners to keep up with them. As more and more areas upgrade to trunking systems, machines like the 246 will become the norm.
Dec 21, 2009 | Uniden BC246T Handheld Scanner
Programming
Go to Don Starr software link at:
http://starrsoft.com/software/win96/default.asp
The best $30 you will spend to make the Pro 96 sing for you.
Also use:
http://www.radioreference.com/
This site has all you need to get going and a direct download of frequencies and talk groups for trunked systems...
Cheers,,,Tom M sends
Oct 04, 2007 | Radio Shack Pro-96 Scanner
Radio Shack Pro-2096 Base Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
