HP PC will not boot up
My HP Media Center PC will not boot up. The CD Rom drive keeps blinking and trying to read something (whether or not there is a disk in the drive) but the monitor won't come on nor will windows start.
The CD rom just keeps blinking on forever.
Is the CD rom the problem and if so is there a way to turn off the CD rom so the PC will start windows?
  • jeffbradley Jul 06, 2008
    Thanks. The monitor doesn't show anything though it is on and connected. No signal is getting to monitor. Is there any alternative to opening up the tower (e.g. keystrokes)
  • 197 Answers
The first thing that i would do is see if you can go into safe mode and try booting from there . when it comes up choose the one that is already hilighted. if it still wont boot then open up the tower and unplug the power from the cd rom. if it is your cd rom i would go and by another one or return the cd rom.
hope this works
Posted on Jul 06, 2008
  • Doug Hudson Jul 06, 2008
    whats on the back of the tower is there screws or any typ of screw. if so then you will have to take out two of the screws and one side of the tower should come off
Hi I'm Tony from the Philippines and I have a Compaq presario f756nr notebook pc (to be exact), i want to reformat my laptop and the problem i am facing now is that when i try to use my cd/dvd rom drive to...
Hi Tony,
Thanks for the details you have mentioned. The steps you have taken are correct and if the System/ hardware is ok, it should boot from CD Drive. Whenever i have faced such an issue, i always started afresh to check each hardware (CD, DVD, ROM, Hard Disk, Cables, Connections etc) and most of the times the issue was optical drive or CD/DVDs.
So, I recommend that make sure that the CD/DVD ROM is functioning properly. When the system is set to boot from CD/DVD, it must try to read CD/DVD after power on. It is indicated by spinning of the optical drive and blinking CD ROM LED. If there is a bootable CD in the drive, it should boot. You may try to boot the system through DOS bootable CD. Also, if you still have the OS on your system, you may check the CD ROM through windows.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP Compaq Presario F756NR Notebook
HELP MY COMPUTER WONT READ ANY CD'S EXCEPT A DVD,, WHAT IS THE PROBLEM?? ANY HELP
hi
you have either one of these ..
5187-5619 = DVD-ROM/CD-RW combination drive - 48X CD-R write, 32X CD-RW rewrite, 48X CD-ROM read, 16X DVD-ROM read
EL436-69001 = 48X DVD-ROM CD-R/RW optical drive - 48X read, 32X read, 48X read, 16X max write speed
make sure you buy CDs or DVDs which are speed compatible to your optical drive or COMBO drive speeds
if you are busying compatible speed CD media, then take some compressed air (can) and clean the drive bay and inside the optical drive area, to dedust it .
go to this site and review all the related sites .. read carefully and try to figure out what the possibility (issue) is .
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=15887&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=431075
if ALL this fails, you may have to replace the DRIVE itself
i hope this helps
Nov 08, 2010 | HP Pavilion a705w PC Desktop
Media center does not play cds or dvds please help
You have to check your CD/DVD Rom to make sure the device is not faulty.
Open your Windows Explorer, insert any CD/DVD to see whether your CD/DVD is able to read the the disk.
If it cannot read the disk, most probably the CD/DVD rom is faulty and you have to replace it.
Aug 17, 2010 | Microsoft Windows XP Media Center Edition...
Wont boot, not even from CD, won't open setup or boot options
At first you insert your system disc on your cd/dvd rom driver and restart your computer. Now press F2 or DEL until you get your BIOS option. Now go to advance option then boot option in that. Now change your first boot option to CD/DVD ROM DRIVE and save that change by pressing F10. Now restart your computer and continue your installation. Thank you.
Jun 10, 2010 | HP Media Center m7250n (ED842AA) PC...
Media read error check cable
Your computer tries to boot from various devices:
* CD-ROM
* disk-drive
* USB memory-stick
* 3.5" diskette
* network
in some order that has been configured (either at the factory, or by you, during BIOS SETUP).
So, if there is no media in the CD-ROM, no media in the diskette drive, no connected USB drive, then it will boot from either the network (if there is a network-cable that is connected to a "boot-server" system) or from the disk-drive.
So, is your disk-drive getting power?
Is the "data" cable between the motherboard and the disk-drive connected?
Is the disk-drive "dead" (not spinning) ?
Check your disk-drive.
You may need to purchase a new disk-drive, connect it, and reinstall Windows.
Apr 02, 2010 | Gateway MD2614u Notebook
What is the boot media?
Boot Media - Floppy Disk, CD ROM, USB/Flash Drive used to boot the computer.
Mar 31, 2010 | HP Pavilion Media Center M1070n...
My E drive is not working. how can i fix it.
Have you tried cleaning the laser assembly? If your OS still sees the drive then it may just be having trouble reading.
Try this
First try to boot from your xp cd. If it fails to boot from the cd then your drive is screwed. If it does boot from the XP cd then ONLY try the following
Click Start.
Click Run.
The Run dialogue box appears.
Type devmgmt.msc in the run dialogue box and click OK.
Click on the plus sign next to DVD/CD ROM Drives.
Locate your DVD/CD ROM drive in the list of devices.
Verify the type of drive in your computer and that the type of media you are using is supported by the drive. Use the table below to determine the supported media types.
DVD+/-RW Read CD or DVD media, write DVD+RW, DVD-RW, DVD+R, DVD-R, CD-R, CD-RW media.
CD-RW/DVD Combination Drive To read CD or DVD media, and write CD media.
DVD-ROM Drive To read CD or DVD media.
CD-RW Drive To read and write CD media.
CD-ROM DRIVE To read CD media.
Try cd drive now before trying the next step
Click the Start button, right-click My Computer, and click Manage.
The Computer Management window appears.
Click Device Manager.
Click the (+) plus IDE controllers section.
Double-click the appropriate IDE channel.
The IDE Channel Properties window appears.
Under the Advanced Settings tab, verify that the transfer mode is set to DMA if available.
Click the OK button to save the change. At this point, you may need to restart for the change to become active.
Check to see if the drive will work in safe mode. I it still does not work Update the firmware for the optical drive.
Click the Start button, click Run.
In the Open box, type Regedit, and then click OK.
Click the plus sign (+) next to HKEY_LOCAL_MACHINE.
When you click the plus sign (+) next to a folder, it will expand displaying the folders it contains in the left-hand pane of the Registry Editor. When a folder is highlighted, its contents will be displayed in the right-hand pane of the Registry Editor.
Click the plus sign (+) next to SYSTEM.
Click the plus sign (+) next to CurrentControlSet.
Click the plus sign (+) next to Control.
Click the plus sign (+) next to Class.
Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
On the right side of the window, click UpperFilters.
Click Edit on the menu bar.
Click Delete, and then click OK.
On the right side of the window, click LowerFilters.
Click File, and then click Exit.
Restart the computer normally.
If all these steps fail then you will need to replace your drive.
Thank you.
Sep 17, 2009 | HP Pavilion dv9000z Notebook
I am having a problem with my hp cd/dvd burner drive. when I go into wmp and try to burn something it tells me to connect a burner and restart the player, please help
What version of Windows Media Player are you currently using? If it is not up-to-date, try updating Windows and Windows Media Player. Then attempt to create the CD.
If that doesn't work, try updating the driver for your CD-ROM drive. Navigate to HP's Support Site, type in your machine model and search fot the CD drivers there. Update the necessary drivers and attempt to create the CD once more.
I hope I was able to help. Good luck!
Aug 08, 2009 | HP Pavilion Media Center m9340f Desktop PC
Software problem
hi.. more likely the drive is not showing up in teh device manager
hold windows key + pause
click on hardware tab and then
you will get the device manager
under dvd/cd-rom drive you will see you drive
right click and delete it so windows can reinstall the driver
go back to you cd recording software
under the top menu see if you can locate something
to do with recording properties or options..
keep me posted
May 21, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
