Question about ASUS Computers & Internet
Notebook Power on. Plugged into mains power. All indicator lights on. Cannot get the screen to open. power switch doing nothing. I bought this lap top yesterday.
  • 197 Answers
Take it back and tell them what the problem is. if it is under warrenty they have to fix it
Posted on Jul 06, 2008
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
Just bought a second hand Asus C90S. OPened up and only orange light on at battery indicator.plugged in mains - nothing. Left on 6 hours-nothing. Read manual ref emergency switch off - pin into slot...
pull main battery, plug it in. does it work? Yes, then replace battery (probably not covered under warranty). No, bring it back to where you got it.
Feb 25, 2011 | ASUS C90S Notebook
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
Lap top can not start even button lights
do static discharge
disconnect battery and all peripherals. disconnect from mains. press power button and hold for 30 sec.
Connect to mains and try to turn on again
If it will not start - mainboard needs replacement
Sep 14, 2009 | Toshiba Satellite M40-S417TD Notebook
When the lap top logs off front light stays on
Do you still have the power cord plugged in? There are indicator light s for Battery operation, power on, hard drive activity. If you just logged off but the laptop is stillpowered on, then there will be a light indicating that. If you powered off the laptop but left it plugged into a wall outlet, then there is a chrging indicator that will stay lit.
Sep 11, 2009 | Dell Inspiron 6000 Notebook
Will Not Turn on
Which pin did your husband reposition, I assume it was the one inside the laptop. He may not have connected the power switch cable back in properly when he rebuilt the laptop. Ask him to carefully check all the connections by opening the case again. These sort of repairs are normally carried out by experienced tech engineers. Some dc connectors (the bit that the power supply plugs into) have to be resoldered to work correctly or be replaced completely. The fact that you were able to charge the battery means little at this stage I'm afraid. Let me know if you need more help.
Jun 08, 2009 | Toshiba Satellite M115-S1061 Notebook
Laptop wont boot
am sorry to say that laptops are more delicate falling from your laps could course alot of damage on the motherboard please visit your nearest service center for help
Dec 15, 2008 | Toshiba Satellite M45-S265 Notebook
When you turn it on nothing happens
I just bought a lap top and no nothing about them it is a hp compaz nx 5000 I turned it on and the screen is still black don't know how and where to turn the monitor on
Apr 05, 2008 | E-Machines M5310 PC Notebook
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
