Question about Samsung CLP 300 Laser Printer
Printer says printing but does not print
I have 2 CLP-300, each connected to an Apple Express Airport base station, so I can print wirelessly. Both printers worked for a while (2 month) and then stopped printing. The red light flashes constantly. Often a printing job gets stuck on printing at 90% and it does not complete the job. I was able to make it work again by removing the printer from the printer list and ask the computer to browse for it again. It stopped again and that trick no longer works. The printers also don't print with a direct USB cable to the computers. Do you know what is happening? Both printers are having the exact same problem with Mac or Windows machines.
Thank you,
  • piers721 Aug 08, 2008
    ...Sounds like the same problem! I send the job to print over my (Mac) Airport network, and it instantly
    appears in the print monitor window, then stops at some point -
    generally more than 50% and less the 100%- I only just got this printer
    and it printed well the first time, then without changing anything,
    this started. I have tried restarting computer, network and printer,
    changed to brand new cables, and Airport is fine otherwise...
This post regarding the CLP-300/AirPort problem appeared on the Mac forums in June:
"This is not a known issue. The reason for you to face this particular issue is that these are both 2 GDI printers. Both these printers are designed to be DIRECTLY connected to a PC or MAC. They are not designed to be connected to any type of Printer Server, Airport Extreme Base Station or Powered/Unpowered USB Hub.
If the printers are to be used over a N/W environment then you may need either CLP-300N or any other N/W capable printing device. The other option would have been to use any device that is PCL or Post Script capable. These are not host based would have been better to suited this type of environment. Even though the previously mentioned methods of connections are still not recommended they would have been better suit as they are not host reliant drivers.
As to getting a refund it would highly unlikely as it is not a fault with the printer or drivers only as mentioned they are both designed with the intention of being DIRECTLY connected."
I hope this answers your questions. If you have any further questions please do not hesitate to contact me.
Kind regards,
IT Technical Support
Customer Contact Centre
Samsung Electronics Australia
T 1300 362 603 | F T 61 2 9746 6691
Quad Samsung, 8 Parkview Drive, Homebush Bay NSW 2127
Web :
Posted on Sep 20, 2008
  • KWBum Sep 20, 2008
    Not being an expert, I didn't really understand the answer. Basically, as far as I understand the explanation, it seems to me that one cannot use the CLP-300 with ainy of the AirPorts. Is that about right?
  • Robert Jan 02, 2013
    Hello to the IT Technical Support team in Australia - maybe you can help me too ? I am trying to connect the Samsung CLX-3175fn to Apple airport express. The printer works for the MacBook Air prefectly and a new windows 8 computer. It does not work for a windows 7 pc - and only send a "ping" to acknoledge the print command but does nothing. Any ideas - would really be appreciated. Thanks, Robert.
Printing using an Apple Airport Wireless network
I am not familiar with apple - However
Apple suggests resetting the printer system in the link below
Also driver may need updating which can be downloaded from brothers web site.
Other possibility I thought of is the port being used may not match the port that printing uses. port 515 TCP could be being blocked by a firewall of some kind or is not set up correctly.
Nov 12, 2015 | Apple AirPort Express (M9470Z/A) 802.11g/b...
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
MX310 - Wireless network printer used on an Apple Airport Extreme
Here's what worked for me: I had everything set with my wireless network which included an Airport Extreme base station and two Airport Express units to extend range. I still couldn't plug and play with my printer. 1. You have to plug your printer into the Airport Express, turn it on, then select a document to print from your computer. 2. Select print from the pulldown menu (or select 'command P' on the keyboard). 3. When the print dialog window appears, go to the "Printer:" selection bar near the top of the window and select "print & fax preferences..." 4. This opens a new window, "print & fax." Near the bottom left of this window just below an icon list of your printers are a "+" button and a "-" button right next to each other. 5. Click "+". Yet another window opens which will reveal a list with your printer on it. 6. If you don't see your printer, click the "default" icon in the top left hand corner of the new window. 7. Select your printer, then click "add" on the bottom right hand corner of the window. The window will close automatically and return you to the "print & fax" window. 8. You should now see your printer in the list. You may say, "My printer was already in the list," but that's not good enough. The process you just went through enabled the computer to detect it on your network. You may want to use the "-" button to remove any previously listed printers from the list in the "print & fax" window. 9. Now you should be able to close the "print & fax" window and get some wireless printing done.
Mar 19, 2009 | Canon PIXMA MX310 All-In-One Printer
The AIR PORT EXPRESS does not like my new Vista HP laptop
get the tp-link wireless print server then configura it then get the wireless printer
Mar 02, 2009 | Apple AirPort Express Base Station with...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
have you tried reinstallting the printer softwares??
if not try that..
Aug 05, 2008 | Samsung CLP 300 Laser Printer
AppleĀ® - AirPort Express Wireless-N Base Station
No. The airport express just has a shorter range. You can use both a regular base and express to extend the range further. Also, the express can be used at your home stereo. You can play your Itunes library directly to your stereo with an adapter to the express. Anyway, the express is just a less powerful wireless, with some special features. We print through it and use it exclusively. May add base station later. Good luck.
Jun 16, 2008 | Computers & Internet
Using to Print Wirelessly
mac or windows? Here's the airport express firmware update which resolves a lot of known issue regarding the express.
May 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Samsung CLP 300 Laser Printer Logo
481 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
