It will ask for the PUK code when you try inserting the wrong pin
for 3 times ...
so to get the PUK code follow these steps:
1. call to your network provider s customer care from some of your friends number of the same network ...
tell your number & ask them for the PUK code..
2. they may ask you the details of sim like in whose name it is etc..
answer that ...
3. after that they will provide you the PUK code note it down
4. enter the noted PUK number to your cell ...
5. your sim will get unlocked ....
caution:
if you try inserting the wrong PUK codes for more than 5 or 10 times it
will completely block the sim after that you must contact the network
provider s shoppe only to get it unlocked ..
remember this ...
this solves your problem ...(i got confused by your problem you didnt mention it clearly that the pin is blocked or PUK but also i have included both here just read the above)
any doubts you can reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
I NEED HELP I JUST GET MY PHONE AND IT ISA BLOKED
SOURCE: My phone is PUK blocked
PIN CODE is SIM dependenet and not phone dependent
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times,
This code is OPERATOR specific and not phone specific and you have to call you operator and get PUK if PIN is blocked...
if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM
NOTE: You should ask your service provider,get the PUK,
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Testimonial: "This was exactly the answer I needed. Thanks!"
SOURCE: forgot puk code
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the puk code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
SOURCE: puk blocked
Call your network provider they can give you the PUK unlock code. Just don't use your lock sim until you got the PUK unlock code.
SOURCE: How to input PUK number
i think u have tried wrong code several times u need to go to ur service provider they can help u in this
pls rate me well !
i noe my pin but dunnoe the puk code .. can u all please help me?
my LG VU touch screen says PUK blocked on it and a picture of a little card that looks like my SIM card. i took everything out and put it back in. turned it off. plugged to to my charger. nothing helps it. that is all it says. help me please!!!
