Question about Dell Latitude D600 Notebook
How to connect my dell D600 to TV
I bought a cable s-video to RCA but I could not see anything in my TV. What can you suggest I should do?
Thanks,
JLR
    Genius:
  • 2,028 Answers
Not all TV's are designed to connect to a computer, and some don't have the resolution quality expected if they do. Research the make and model of the TV to see if it's compatible.
Posted on Jul 07, 2008
How to connect my lg47lg20 tv to my dell inspiron 4150 to watch movies and shows
The cell inspiron you are using has a s-video port , for conneting external dispaly.
If your lg TV has and s-video port , you can connect the laptop to the tv susing an s-video cable.
In case not, then you would have to buy and install an S-video to RCA cable, which cab bought from click to buy.
Thanks for using Fixya
Proton
Jul 05, 2012 | Audio Players & Recorders
What cable do I need to connect latitude D600 to a hdtv ?
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
Nov 22, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 PC Notebook
your s-vidio out on the laptop only transfers vidio, you need to use a headphone to rca jack cable pluged into your headphone port on laptop and plug rca into back of tv or vcr or s-vid converter box
May 31, 2009 | Dell Latitude D600 Notebook
Can I connect my dell latitude d360 laptop to my tv?
When you connect the VGA cable to the TV you will need to hit the FN button + F5 on your keyboard, that will change the dispalys from internal to external. if you hit FN+F5 again you can have both the laptop and the TV screen on.
I have a Dell latitude D600 laptop
The D600 has no TV out option, the only Output for visual display is the monitor VGA port.
You would need a converter for the normal VGA to DVI Cable.
Mar 22, 2009 | Dell Latitude D600 Notebook
How do i connect cable tv to my dell 2200mp projector
You can connect it directly with a composite cable. There would be a RCA(yellow) video output on the back of your cable TV. This is then connected to Video input(yellow) f you projector.
If your cable TV has Component output (threr RCA cable Green, Red, Blue), then these thre RCA could be connected to the similar one available on your Projector.
You could connect your sound als o thru the RCA out of Cable TV and input of Projector. But if you have a good AV Receiver or a sound system then it best suited for it, since the projector speaker is mono and only 2Watt output.
Let me know if there are any specific inputs required
The Dell 2200 mp projector has the following compatibility
:HDTV: 1080i, 720p
EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes
Mar 03, 2009 | Dell 2200MP Multimedia Projector
How do I connect my laptop to my tv
Right click on desktop. Select display properties tab, select the Extend windows desktop checkbox then click apply.
Jan 31, 2009 | Dell Latitude D600 Notebook
Conection to TV using S-video on Dell D600
Google this and read the forums... d600 s-video out
Dec 10, 2008 | Dell Latitude D600 Notebook
Tv to laptop
disable your laptop screen try that jules
Apr 26, 2008 | Dell (04U621) for Latitude D600, Inspiron...
Dell Latitude D600 Notebook Logo
Alun Cox
