Question about Panasonic DVD-RV31 DVD Player
Panasonic DVD RV31 does not read DVDs created by Windows Movie Maker
I am using Windows Movie Maker on a Sony Vaio to create home movies. I am using a DVD+RW disc. These almost do not play on the Panasonic DVD RV31 player. What could be the issue? Is this Panasonic model capable of playing DVD+RW discs? if not, what format does one use? How to fix?
The Panasonic RV31 plays commercial movies well.
  • SleeplessDVD Jul 08, 2008
    In the end I think what worked for me is to use DVD-R only, and also to start the video using the Power-ON button (not Open/Close or Play).
    We'll see how long my "solution" works. Thanks for trying, Cordell.
The only thing that has worked for me is to make a copy of the disk after burning it in Movie maker.
Cordell
Posted on Jul 06, 2008
I have prepared a home movie on Windows Movie Maker and when I copied it to a DVD it would not play on a dvd player can anyone tell me what I did wrong please thanks joe
The reason why the DVD disk you created may not contain the file format the DVD player recognizes. On a normal DVD disk there are two folders - AUDIO_TS and VIDEO_TS folders. The video files are located in the VIDEO_TS folder. This video folder contains the VTS_xxx.vob video files (the video files has a .vob extension).
The video file you created may have a avi or wmv or mov or mpg extension, whilst these video files can be played on a computer but they won't play on a DVD player.
Check the movie software you are using and make sure it creates the correct file format for a DVD player.
Jan 07, 2010 | ASUS Computers & Internet
I used a disk cleaner because I kept getting a "No Disc" message after putting one in for recording. (same disc I had used previously that worked). It still reads no disc,then I put a recorded movie in and...
It sounds like the unit may be beginning to fail. DVDs are created in one of two ways - they are either burned (when you create one with the recorder) or they are stamped (most commercial DVDs are created from a master this way.) As the unit ages, the strength of the laser used to "read" the DVD begins to get weaker and weaker, eventually becoming too weak to read even the best DVDs. Not all commercial DVDs are created equally, which means some may have a deeper, neater pit pressed into the substrate making it possible for a weak signal to get reflected and read by the hardware (hence, you will experience the ability the read some commercial DVDs and not others.)
DVDs you create at home creates the "pits" by focusing the laser beam on a dye layer and causing a dye to change from translucent to opaque. Where the dye is translucent the laser beam is reflected back to the reader and where it is opaque, not. We get the 0 and 1 state that digital signals use to reproduce/transmit signals in this way.
You may be able to get the unit serviced and have the board that sends/receives the laser beam replaced - but that may be as expensive as buying a new unit, complete with warranty.
Jan 04, 2010 | RCA DRC8300N DVD Recorder/VCR
Burning DVDs
Hi
Please use ulead or nero burning software for make dvd it ll be help you
Harry
Nov 01, 2009 | Computers & Internet
Can't import vob files into windows movie maker
To use Vob files with movie maker, they need to be converted first. This can take a little while, but there is no other way, as windows doesn support dvd playback by default, and whilst codecs will give you playback, movie maker will not accept them, even with the codecs. To convert your vob files to "avi" (the format needed for movie maker) yoou will need converting software. Most of this is very expensive, but thankfully, one of the best is actually free! It's name is "super" and it can be found at the following web address http://www.erightsoft.com/S6Kg1.html
By the way, the download link is at the bottom of the page.
Wish you the best of luck,
06castwo
Jun 02, 2009 | Sony VAIO VGN-CS215J/W Notebook
Will not complete movie burn to dvd ''write error - Hardware error
In the program temp file path has enough space and Your drive should indicate (written on the front the drive door) a -R or +R make sure you are using -R or +R DVDs. also make sure you finished product does NOT EXCEED the capacity of the given media. They all hold diferent amounts. Multi layer discs, DUAL layer, High capicity.... Which should also be indicated on the drive door!!!! Hope this helps
Mar 27, 2009 | Roxio Creator 2009 for PC
Can't import video into Windows Movie Maker
Windows Movie Maker is a basic video editing and creating software developed by Microsoft. It contains features such as effects, transitions, titles/credits, audio track, timeline narration, and Auto Movie. The accepted formats for import by Windows Movie Maker are WMV, .AVI, MPG, .ASF, .WMA, .WAV, and MP3.
Puzzled about how to import DVD to Windows Movie Maker for further editing? iOrgSoft DVD Ripper can do that job. Not only rip DVD to Windows Movie Maker acceptable videos including AVI, WMV, MPEG-1, MPEG-2, ASF, but also convert DVD to MPEG-4, MOV, AVC (H.264), MOV, 3GP, FLV, SWF.
Tutorial: How to Rip DVD to Windows Movie Maker, import DVD to Windows Movie Maker?
Step1: Locate your favorite DVD to the program-DVD to Windows Movie Maker.
Step 2: Specify output video format compatible for Windows Movie Maker, like AVI.
Step 3: Click “start” button to start the process of ripping DVD movies to .AVI video.
[img]http://www.mp4kits.com/Guides/WMM/dvd-to-windows-movie-maker/importdvdtowmm/convertdvdtoavi.jpg[/img]
Aug 28, 2008 | Lite On Computers & Internet
Vista crashes while publishing movie in Windows Movie Maker/DVD Maker
i just found out the problem.
I have nero 7 installed on vista. To fix the vista movie maker crash when rendering, I just renamed this folder
C:\Program Files\Common Files\Ahead\DSFilter
Renamed DSFilter to something else. VMM no longer crashes and when I want to use Nero again, just rename DSFilter back to normal.
Jun 28, 2008 | Computers & Internet
Windows Movie maker problem
When you publish it, do it to dvd quality. This should create a windows movie file which is the simplist form for windows media player to read. If that does not work contact me and we will go through step by step.
Feb 28, 2008 | Computers & Internet
Can u Create a movie(dvd) by mixing MiniDV format with JPEG?
Yes, this is frequently done. I think all video editors can do this. Windows Movie Maker or Roxio's Creative Suit are two that come to mind. Most of the lower cost products probably lack the ability to control the video and audio seperately. Someone else may be able to provide more options.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Panasonic DVD-RV31 DVD Player Logo
256 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
