Question about Microwave Ovens
How can you check to see if your microwave oven is working at full power
  • Microwave Ovens Master
  • 9,086 Answers
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or 70 if you're using a centigrade thermometer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
Is there any way to turn up the heat to the microwave
microwave ovens work from radio waves
full power is full power and if that is not enough then take it to an appliance repair shop and have it fixed
Jun 18, 2015 | Microwave Ovens
Gh6177xps
Your full model number would be either GH6177XPS1, GH6177XPS2, GH6177XPS3, or GH6177XPS4 as found on the model tag. I mention that only if you need to order parts.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
On the tech sheet for our model, trouble code F7 is discussed:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See "Checking Inverters."
9. Check operation of all interlock switches.
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Sep 07, 2012 | Whirlpool Microwave Ovens
I have a that microwave gh7208xrs that shows a error code F7 HVSMPS feedback
The controller is not getting the high voltage switched-mode power supply feedback signal.
Sometimes this is due to a defect on the HVSMPS (inverter) or a bad connection from the HVSMPS to the controller.
Due to the voltages involved, I do not recommend that an inexperienced person attempt to troubleshoot an inverter.
In the event that you or someone you know wants to look into it, see these safety warnings first.
It tells you this:
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control
board.
8. Check wiring to the 1200W inverter and control system. See "Checking
Inverters."
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
I'd suspect 6 through 8 first.
Jul 08, 2011 | Whirlpool GH7208XRS Stainless Steel 1200...
Mu accuwaave makes a short noise intermittenly while trying to heat
Is your microwave oven set to full power when the intermittent noise occurs?
If it's set to a lower power rating, then the noise you describe sounds perfectly normal.
At a lower power setting, the device which creates the heat or microwaves, called the magnetron, switches on and off intermittently so that the food etc. is not cooked too fast.
This is quite normal & you should only be concerned if the noise occurs while the microwave oven is set to full power.
In that case you will have to have it checked out to see what the cause is.
Best wishes,
Graemevm
Mar 24, 2011 | Whirlpool Accuwave Microwave Oven
Microwave won't let me reset power level settings. Power level of 1 only
There is a part called a triac, it is responsible for switching power levels in the microwave oven, when it becomes defective it won't let you get passed the first setting, the semiconductor must be replaced in order for it to work at full capacity.
Feb 13, 2011 | Oster OGB61101 Microwave Oven
My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
NAR_JennAir_CustomerExperience@JennAir.com
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
What is the F7 code mean?
According to the technical sheet found hidden inside the unit behind the controller and online here:
2. After 40 seconds, check to see whether this solves the problem. (Possible reason: Over temperature protection for the magnetron opened.)
3. Check resistance of the magnetron thermostat. It should be close to 0 ohms.
4. Check the magnetron.
5. Check wiring to the 1100W inverter and control system.
6. Check operation of all interlock switches.
7. If switches operate correctly:
- Replace 1100W inverter.
- If problem persists, replace power supply board.
8. Plug in microwave oven or reconnect power.
Sep 08, 2010 | Whirlpool Accuwave Microwave Oven
2 difrent microwave problems
is the motor with the fan on it working,thats most licklely the problem
Jul 06, 2010 | Sanyo EM-C1800 Microwave Oven
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Whirlpool microwave oven
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It says:
If for some reason your tech sheet is not there, you can download it here.
We regularly repair control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 30, 2008 | Whirlpool GH4155XP Microwave Oven
Microwave Ovens Logo
108 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
