Dell Inspiron 1526 wireless
Hi! I just got a new laptop, and I tried everything but the wireless wont connect, it does pick up the signal though. My other dell works perfectly fine, so I don't understand what the problem is.. Thank you!
    Genius:
  • 2,028 Answers
Usually this is a driver problem, in which you have the wrong driver trying to configure the wireless. Some wireless drivers and cards are so similar that they will install and either show and network but won't connect, or show the card working but won't see the network. Take the cover off the bottom and get the make and model of the card, then find the right driver either at Dell's support site or driverguide.com. Dell uses several different wireless cards and checking the make and model of the card is the only sure way of knowing you have the correct driver.
Posted on Jul 06, 2008
So I turn on my Dell Inspiron 1526 and all that happens is the fans fun but nothing else. No hard drive lights at all. Suggestions?
Go inti the BIOS settings and see if the BIOS detects the hard drive.
If not then re-seat the hard drive to make sure it is connected properly.
If the hard drive still isn't detected, then most likely the hard drive is faulty.
In this case to get the Dell operating again, replace the hard drive, install Windows on the new hard drive plus install the Dell Inspiron 1526 device drivers and your programs.
Jan 12, 2011 | Dell Inspiron 1526 Notebook
I have dialup. i can't download or playback music
Check with your local ISP (Internet Subscription Provider) if they have a wireless modem/router so you can connect to the internet wirelessly.
They will be the one to configure your internet settings.
Happy surfing!!! ^_^
Jun 08, 2010 | Dell Inspiron 1526 Laptop
My dell inspiron 1545 wont connect to linsys-g
Your laptop may have a pre-defined Ip address locked in for your work connection. Did your buddy use the laptop at your place of employment, or was it used at his home? Sometimes an ip is entered manually in the tcp/ip menu locking it to a certain address. To check this opem metwork connections in control panel and right click your wireless device then choose properties and left click. Scroll to the TCP/IP line and go to properties. Make sure everything thereis set to automatic.
Mar 13, 2010 | Dell Inspiron 1545 Notebook
Have wireless internet but no connection to laptop. where's the switch on the laptop to turn it back on?
Hi !
Most of the laptop wireless switch is on the side of the laptop. If there is no physical switch, press the Fn+F2(wireless symbol) to enable the laptop. Double check the wireless LAN if enabled in the system setup. To access system setup, press F2 while the system is booting-up.
Hope this helps !
Thanks.
Jan 23, 2010 | Dell Inspiron 1526 Laptop
Instructions on removing the back of a Inspiron 1526 laptop computer
Hi ,
Download the zip file from the following site and open the inde.htm file .
http://laptoprepairmanual.blogspot.com/2009/10/dell-inspiron-1526-service-manual.html
Hope this would be helpful
Thanks
Siju.D
Oct 28, 2009 | Dell Inspiron 1526 Laptop
My wireless will not work
Check your Settings in the Control Panel (Network Connections, as well as Hardware (to be sure the device is enabled!)
Also Check Power Settings in the Control Panel.
Go to Dell.com, Download the Drivers and Software (Everything Relative to Networking)
Reinstall them,
Apr 21, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Wireless connection
hi,
welcome to fixya.com
yes offcourse ur dell inspiron 5100 laptop support wireless connection,and it will detect the wireless connection in ur computer,uninstall and reinstall the wireless driver and then try and connect to wireless connection,and what u can do is that reset the router and then try and connect to wireless network it will definately connect..and it will also detect the wireless signal also........good luck
pls rate this solution its a request..pls
Feb 11, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Wireless router
well..the wireless will pick up any signal..if you want one inside your place, you'll need a signal converter(wireless router) and a cable or dsl(phone com) internet service providor.
May 28, 2008 | Dell Inspiron 1501 Notebook
Inspiron 1526 running windows XP Pro
ALL POSSIBLE XP DRIVERS for Dell Inspiron 1526 are bundeled together and is available for download at the following URL
http://rapidshare.com/files/290508217/Inspiron_1526_XP_Drivers.zip
ALL XP DRIVERS FOR INSPIRON 1526
Regards
-SHrimant Patel-
Apr 14, 2008 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
1,618 people viewed this question
David Payne
David Payne
