Question about Dryers
Have an older clothes dryer. The drum squeaks when it is on & rotating. If I spray the back bushing with lubricate it will stop for a few days, but returns. Have asked a repair shop what can be done. They said "nothing for this General Electric dryer." Works fine otherwise & a shame to discard for squeaking noise only. Any suggestions? Thanks
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=784658&PPStack=1
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 06, 2008
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Squeaking while it runs
There are many reasons why dryers squeak, fortunately, they are often "model" related, so yours will likely only have a few.
Some dryers have an indentation at her rear of the rotating drum, and there are 2 rollers that support the rear of the drum.
These wear out, and sometimes squeak.
Another kind uses a center shaft in the rear, which rides on plastic bushings, and these wear out, which gets noisy.
Several have nylon bumpers in the lower front of the machine which support the rotating drum.
These can wear out, causing squeaks.
Let me encourage you to unplug your machine and "operate" on it, if you are so inclined.
Many machines require only a putty knife to get the top open, and a few screwdrivers and some small sockets to dismantle them.
Be blessed.
Jan 27, 2013 | Dryers
My dryer squeaks
First you should try to determine what the squeak is related to, does it happen every time the drum rotates or more frequently. This will give you some idea of where to look. You should disconnect it , take off the top and get someone to rotate the drum by hand while you listen. Moving parts are dangerous don't put fingers in. Commonly the outer drum bearing or belt idler need lubrication. Don't lubricate the belt. More details if you provide more clues.
Jan 13, 2011 | Frigidaire Dryers
My dryer was squeaking really bad, so I sprayed WD 40 on the pulley & belt, squeaking stopped but the dryer also stopped turning. The pulley still turns but the dryer drum doesn't
The belt is slipping now. Need to clean the WD40 off, use methylated spirits, isopropyl or rubbing alcohol on a cloth.
Jan 02, 2011 | Dryers
When the dryer drum rotates it squeaks. It sounds like it needs some sort of lubrication; however, I do not want oil on our laundry.
you need new felts they go in front of the drum once you remove the raise the top and take the front off they will be right there on the front panel assembly. they are little plastic pieces that the drum ride on if not plastic it will be along wool type cloth right there in the front in the same place.
Dec 17, 2010 | GE DPSR610EGWT Electric Dryer
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Dryer squeaks when clothes are drying
Squeaking can mean bearings going bad or the pulleys needing some oil on them. The pulleys can usually be accessed from the rear of the dryer. The bearings are a different story, you would need to remove outer casing of the dryer to remove the drum to get the bearings behind the drum. I would recommend trying to oil the motor and idler pulleys and if that doesn't fix the problem if your handy you can try to replace the bearings. Its a big job, the bearings are behind the drum and are screwed in from the inside of the drum. In order to remove the drum the casing of the dryer had to be removed, usually the front and the top (the top will sometimes tip back on hinges). After that the drum should slide out with the bearing assembly attached. Installation is the same as removal. {Note: If you find it to be too much trouble, I would just leave it squeak, other than being annoying it won't hurt anything. Also, some dryers have a compartment in the back where you can see the bearing assembly, maybe you can spray some WD-40 in there and see if it stops squeaking. The time you really need to replace the bearings is if your drum is loose, as the bearings have gone bad, not just squeaky}
May 12, 2010 | Dryers
Front load dryer make a horrid squeaking sound as it goes around. Heat's great - it just squeaks!
There are nylon or cloth type guide bushings(bearings) at the front of the drum which may be worn. The drum rides on these to keep it suppurted. You can replace from retailer and or try to lubricate with silicone spray.
Feb 23, 2010 | Fisher and Paykel DE09 Dryer
Our dryer is making this loud squeak how do i get it to stop
ON THE REAR OF THE DRYER YOU WILL SEE THE REAR END OF THE DRUM SHAFT TRY SOME WD40 AND SPRAY A LITTLE AND SEE IF THIS STOPS THE SQUEAK IF IT DOES YOU WILL NEED TO REPLACE THE BUSHING FOR THE REAR SHAFT
Aug 08, 2009 | Frigidaire GLEQ2152ES Electric Dryer
I have an Amana gas dryer that is squeaking. Does something need to be lubricated? If so can I do this myself?
Good Afternoon,
Lubricating would be just a temporary fix. You need to replace the drum rollers. If you think you can do it yourself I'll try to walk you through it. Once the rollers are worn they start squeaking and squealing at a very high pitch. This happens because the roller bushing spinning on the shaft has dried out from the heat. The weight of the clothes in the dryer plus the drum itself rests totally upon these rollers. If you decide to install new rollers clean up the shaft with lite emery cloth then wipe clean. Next apply "High Heat" Lithium Grease to the shaft and inside the new roller bushing, they will last 2 to 3 times longer. Let me know if you need guidance if you attempt to change the rollers yourself.
Have a great day!
Mar 26, 2009 | Amana ALG331RAW Gas Dryer
Dryers Logo
163 people viewed this question
Top Dryers Experts
