Whirlpool washer dryer filled and washed but cut out on drain cycle. Tripped main circuit breaker to house. Disconected both top thermostats on top of dryer heater elements housing and the machine works. If i conect either thermostat in it trips but only on empty cycle. Could both thermostats have gone or is it more likely an element or further back in the electric?
    President:
  • 1,462 Answers
More likely to be the dryer element. disconnect element and then try
Posted on Jul 06, 2008
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
My washer stopped in the middle- and wont turn back on- full of water right before the spin cycle! I have checked the breaker, unplugged it, pulled the knob and tried to recycle it- NOTHING! it is only 7...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The dryer will not start. It does not have any power to operate. I checked the main breaker box and all is good there. What do you recommend? Thank you, Gordon Pearson I1putt22@yahoo.com
The thermal fuse is located at the 2 o'clock position on the rear bulkhead. When it blows because of an air restriction or broken element, the dryer will not run. Check the dryer vent for blockage.
Jan 17, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Both broken?
sounds like an electrical issue for sure, too coincidental that both would stop functioning at asime time, they are independent units and should work separately . i would check your breakers, perhaps it has partially tripped
Apr 12, 2008 | GE WSM2780W Stacked Washer / Dryer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
