Question about Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD Television
Mac Mini - Signal is not compatible with this intput
I am trying to get an Intel based mac mini to display on Sharp Aquos LC-45GX6U TV. I am using a dvi-to-dvi cable.
When initially connected, it worked fine, outputting at 1280x768 at 60Herz. It is not the native resolution for that TV, but close enough to display OK. I tried to play around with resolutions and as soon as I switched to another res, the TV showed a black screen with a message "signal is not compatible with this input". The funny thing is that when restarting the mac, it shows the boot screen fine with 1280x768 at 60hz shown in the right top corner of the TV. However, as soon as it boots, it goes back to the black screen with the dreaded message.
I have tried connecting other monitor(s) and TVs (all of which work fine) and then changing the resolution back to 1280x768, then reconnecting to Sharp Aquos. It doesn't work.
I have tried clearing PRAM and NVRAM - it doesn't work. Still gives the same message.
I tried deleting plist files on the mac (which supposedly save monitor settings) - it doesn't work.
I tried booting it in safe mode and it worked worked, if you reboot in normal mode, it goes back to the dreaded messaged. I then tried going back to safe mode and playing with resolution there. Once I did this, it showed the black screen with the message in safe mode and now the safe mode does not work either.
Please help!
  • 3 more comments
  • RNKC123 Jul 06, 2008
    Re: Solution 1
    The problem is that once the screen goes black, you cannot change anything. You can only connect another monitor (that displays fine) and change from there. I tried chaning to all possible resolutions that the video card can output this way, it does not work. It seems that that mac mini somehow remembers the monitors that are connected to it, so when I am chaning with another monitor plugged in, it changes and remembers the setting just for that other monitor. However, when I reconnect the TV, it remembers the "wrong" resolution for that TV. I tried resetting PRAM and NVRAM on mac mini, which supposed to solve this according to apple support, but it doesn't. I saw a number of other posts on the internet with people describing the same problem, but nobody seems to be able to offer a working solution.
    Please help!
    Comment by Ekse, posted on Jul 06, 2008
    Well the problem is the signal that comes from your mac to the tv.
    -Yes, I know that. The question is how do I change the signal, to something that the TV will accept.
  • RNKC123 Jul 07, 2008
    Eagle 336 - your solution works. It is not perfect, becase DVI does not carry sound and HDMI input does not have secondary input for optical or minijack sound. But at least it shows the picture.
  • RNKC123 Jul 08, 2008
    Now I can only see your solution. Eagle's solution disappeared after your recent comments.
  • 4,889 Answers
I suggest that you get this product for hassle free HDMI connections for your TV. Its a HDMI cable and you dont have to worry about settings as your TV is HDMI ready.
http://www.cablestogo.com/product_list.asp?cat%5Fid=2816&engine=adwords!654&keyword=%28dvi+TO+hdmi+cable%29
Good Luck!
Sai.
Posted on Jul 06, 2008
  • eagle338
    eagle338 Jul 07, 2008
    Try the adapter that Ekse has suggested. It also inputs sound to the HDMI port of the TV.
  • Sharp Master
  • 13,433 Answers
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
  • 5 more comments
  • Ekse Jul 06, 2008
    the signal coming from the laptop is not compatible with the tv so you need to change the format or other settings in there.
    I suspect the signal format changes as you start up, the initial format is ok. but then it changes?
  • Ekse Jul 06, 2008
  • Ekse Jul 07, 2008
    RNKC123 I think you can buy a adapter which also inputs sound to the hdmi port on the tv.
    heres a example
    http://www.gefen.com/kvm/product.jsp?pro...
  • Ekse Jul 07, 2008
    The DVI Audio to HDMI™ Adapter is a unique device that combines digital video (DVI) and digital audio into HDMI™ to seemlessly integrate into the modern home theater. This adapter connects DVI home theater devices or DVI video graphic cards to HDMI compliant digital monitors. This adapter also takes digital audio and encodes it onto the HDMI signal for the full HDMI video and audio effect. With the DVI Audio to HDMI Adapter home theater devices and computer systems can be easily connected any HDMI display for the full digital video and audio experience.
  • Ekse Jul 07, 2008
    also im curious, do you see both of our solutions or only eagles solution at the time?
  • Ekse Jul 08, 2008
    Comment by eagle338, posted on Jul 07, 2008
  • Ekse Jul 08, 2008
    incredible price tag, 299 I didn't notice that before.
Connect mac to tv
Use the HDMI cable input. Select the input number on the TV . If you can't do that then use a Hi def cable between the the Mac and the TV.
Dec 28, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
I'm trying to use my 6 yr old Sharp TV as a remote monitor for my MacBook laptop. The Sharp manual says that port 5 is the correct port for PC hook up. So, I'm hooking up the laptop's mini DVI port to the...
You need to set your MAC video resolution to the native resolution of this TV in PC mode, please read your manual to find out what that is, if the resolution is set too high, the TV will not be able to display it.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 27, 2010 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
I'm trying to plug my laptop into a tv to display my desktop and I can't seem to do it. I got a vga adapter and cord that is plugged into both the tv and laptop. What am I doing wrong?
The 13" White MacBook 2.0GHz has a mini-DVI out port. The adapter you need is
Apple Mini DVI to VGA Adapter
On the TV side, more information is needed. You need to specify what ports on the TV you are using for your signal, and what kind of adapter cable you are using. I suspect this is the component or connection where your problem lies.
May 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a sharp aquos and an older mac mini. hdmi connection. video output is incompatible with tv
There's nothing you can do, not at a reasonable price anyway.
The early years of HDMI were a complete mess in regards to compatibility.
My advice is just don't think about it.
Nov 02, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32&amp;amp;amp;quot; Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Aug 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Connecting Powerbook G4 to Sharp Aquos LC-20D10-W
A few tries, go to the apple in the top left and choose SYSTEM PREFERENCES....it should bring you to:
In the HARDWARE row you should see DISPLAYS. Select that and you will be at:
You have the DETECT DISPLAYS button, and also CLICK the "Show displays in menu bar" box, so you dont have to keep going through menus to configure.
If you look at the F7 key, to the right of the NUM LOCK key (F6), that key allows you to switch from expanded to mirroring or vice versa.
You can also check Apple's Knowledge base....
http://docs.info.apple.com/article.html?artnum=58620
Keep me posted.
Dec 10, 2007 | Apple PowerBook G4 Mac Notebook
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Trutech tv
it`s more likey to be the setting on the display seting menu ati grathics cards are best for two screens
Oct 27, 2007 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD Television Logo
4,857 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
