HP HP Pavilion dv6000z 15.4" Notebook Laptop PC  PC Notebook
Problem for HP HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD...
My "CD-ROM" is missing from "MY COMPUTER"
By eluder98 on Jul 06, 2008
I clicked on "MY COMPUTER" and found that my "CD-ROM" drive is not there. I'vecontacted HP Tech Support and I was told to "re-seat" my CD-ROM drive and if that didn't work to follow the steps below.
-Start-
Step 1:- Assigning the drive letter to the CD/DVD drive.
1.Click Start, Control Panel.
2. Double click on Administrative Tools.
3.Double-click on Computer Management.
4.Click on the "+" sign beside Storage to expand the list.
5.Click once on Disk Management.
6.On the right hand side the DVD/CD drive will be listed as "CD-ROM 0".
7.Right click on the drive and select Change Drive Letter.
8.Click on Add if there is not drive letter assigned or click on Change if there is already a drive letter assigned.
9.Change the drive letter from the pull down and click Ok.changed to 'E' drive .Please check in my computer if the cd/dvd drive is present.
Step 2: Deleting UpperFilter and LowerFilter Registry Keys
1. Click Start and click Run.
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor and restart the computer.
Step 3: Uninstall and Reinstall the Device drivers :
1. Press Windows Key + R key
2. This opens the Run window Type devmgmt.msc and hit enter key.
3. You will get device manager
4. Click "+" beside CD/DVD Device Catagory.
5. Right-click the listed CD/DVD/RW and select Uninstall.
Scan for the HARDWARE Changes.
I recommend you to perform with the steps to get the issue fixed.
-End-
Following the steps above fixed the issue the first time. But now I have the same problem again. HP has told me that I will probably need a new CD-ROM drive... What a surprise that my CD-ROM will need replacement after the 1-yr warranty expires! I have taken care of my laptop ever since I bought it and now after the warranty, some how it stops working? I don't believe that.
My correct product info:
HP Pavillion Notebook
Model: dv6338se
OS: Windows Vista Home Premium Edition
>>>Disregard what it says as my product below for I have only choosen it so I can complete this post. Overwise, it would not allow me to complete. Kept on telling me to "Please enter a valid product"<<<
Please, if you know how I can permanently fix this issue, I would really appreciate it.
Thanks!
-Robert
Comments:
Jul 06, 2008
- No, my warranty just expired.
Jul 07, 2008
- Does anyone thing that I should try the steps again? I have not tried it the second time. If not, then I will have no other choice but to purchase a new drive I suppose.
Same Problem
Mar 02, 2009
-   ok i have done all this,and nothing!!! when i went into the reg.there was no uper or lower filter to remove.the cd drive isent listed anyware in the divice mang.help!!! -   tomtt1
Nov 08, 2008
-   yes dvd and cd driwer keep missi ng
-   Guest
Aug 04, 2008
-   hi i have the same problem.i have a hpdv6500 series running on windows vista.
it seems vista has this peculiar problem.i tried all the above mentioned tricks but alas...nothing helped.now i have to replace it.its a very common issue with HP.luckily my warranty period is still valid...the 1year...lol
and oh yeah mine is only a couple of months old.and i love my laptop and taken good care of her.yet a problem like this surprised me.-   Guest
Best Solution
posted on Jul 06, 2008
Helpful)
antiochpc
Rank: Guru  HP Expert
Rating: 87%, 1238 votes
Actually, the tech was right. It is not uncommon for optical drives to go out just like that. Since you've tried the steps listed above and your computer still cannot see your optical drive, then the drive must be replaced.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
gunjansarkar
Rank: Guru  HP StaffHP Staff
Rating: 94%, 269 votes
if the drive still does not work call hp invent an ask them fora free replacemant if u r in warrenty
Was this helpful?
Yes
No
Solution #3
posted on Sep 12, 2009
Not Rated)
abadulase
Rank: Master
Rating: 0%, 0 votes
Hi Friends,
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
Was this helpful?
Yes
No
Solution #4
posted on Aug 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
HHHHeeeeellllppp ..... I'm having the same problem with my Compaq laptop, the drive still opens and close when i press the button on the side, but nothing can be seen in 'My Computer' .. and the device manager doesn't show up CD/DVD Drives .... there's just no where i could 'communicate' with the drive, everything just went 'poofed' and gone.
I've did the UpperLower filter thing and it's still not working. But I'm quite sure it's some software issue ... but i hadn't install anything not known .... help~~ and HP/Compaq laptops start giving me tons of problems after just 2 years. My Vaio after 4 years still running top notch problem free
Popular Solutions for HP HP Pavilion dv6000z 15.4"
Questions and Unsolved Problems for HP HP Pavilion dv6000z 15.4"
Do you recommend HP HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook?
Answer
Answer
i am having a trouble in signing in to my newly download yahoo messenger version 10
Answer
hp dv 6700 when you push the power button it comes on then goes right back off with battery in or... (More)
Answer
we get green colour images from webcam on our hp pavillion dv6700 notebook pc. ( Its CyberLink... (More)
Answer
i need a schamatics for the power supply board im trying to go around the plug in and wire streight... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
