Question about Roper RS22AQXKQ Side by Side Refrigerator
Side by Side Can't find model # Not cooling enough
Roper Side by Side Cools but not enough to keep frozen foods.
Just inside door is hot to touch. Can hear the fridge running and feel cold air coming from vents inside fridge and freezer but does not get cold enough to keep frozen foods.
Thank you for any help. Have looked all over and cannot find a model number or any numbers at all.
  • haileebear Oct 07, 2008
    everything in the freezer thawed and all the ice melted(which was alot)
    i can hear it running but its not freezing anything and im not even sure if the fridge is cooling anything?
I cleaned condenser coils with vacum, emptied the defrost tray and vacumed all the dust from the unit, unplugging first of course. Now it is working just fine. Thank you fixya for all your help and postings.
I still can't find the model number anyplace on the unit. This unit is only 2 1/2 year old but no model number to be found on the unit. But
Posted on Jul 06, 2008
GE Profile refrigerator does not get cold enough to keep food. The compressor is humming but even after having it plugged in for 3 days it has not frozen anything or kept any of the food cold.
Could be the t stat not shutting the unit off..so it runs all the time untill it freezes the evaporator in the the freezer then it runs and runs and gets hot...or if it has had a compressor replace before..the freon level what not put back in thr right way..meaning its overcharged, or undercharged..this will also do this...The coils are dirty under the unit...
May 29, 2014 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Noticed that the fridge is not cooling lowered the temp settin still not cooling. freezer seens to be keeping food frozen but things in the door are soft.
Culd be bad news. I would check to make sure the condenser fan motor is working properley first off. If it is running continuously along with the compresser, I would clean the condenser and call a repair man. What has happened is the compressor has been running too hot, and the oil gets to the point where it separates, that is called the waxing point. Then the oil evaporates into the refrigerant then cools off in the capillary tube ( the metering device into the evaperator) and coats the inside and creates a smaller hole for the refrigerant to flow through and boils it off earlier in the evaperator not allowing the same cooling effect. You will need to call a tech in for this one. Good luck
Sep 09, 2012 | GE Profile 21.6 cu. ft. Side-by-Side...
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
Lfx25971 will not dispense water
My water dispensor INSIDE the door froze up.... GE
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Jun 08, 2012 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Will not dispence water
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
WATER WILL NOT FLOW
Oct 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Roper side by side refrigerator gettig very hot to
Most side by side units have a hot return gas line that is attached to the "mullion strip" to prevent sweating or moisture build up which could cause mold to build up on the door seal. The heat you feel is normal, however excessive or continuous heat is a symptom of the unit running too long.
Below is a link provided by www.repairclinic.com, which will help you understand how a refrigerator works.
Tip: Make sure door seals are sealing adequately and keep entry time to a minimum during high heat periods. Use the rule "Get in, get what you want and get out"
http://www.repairclinic.com/0088_4_3.asp
Aug 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
143 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
