Question about T-Mobile Sidekick II
Menu button won't work on Sidekick3
I have a side kick 3 and the menu button fell off, and so I've been using a bobby pin to press the button and now it doesn't work. i think it got stuck or something. any suggestions?
please help :]
    Problem Solver:
  • 12 Answers
You may need to get a new one
Posted on Jul 07, 2008
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
Tip
Service menu codes mitsubishi
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
# Using the remote control press:
{MENU} {0} {3} {5} {3} buttons.
{MENU} {0} {3} {5} {7} buttons.
# Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
# {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
# Press the {ENTER} button to save the change.
# Press the {MENU} button twice to exit service menu.
{MENU} {1} {2} {5} {7} buttons.
{MENU} {1} {2} {5} {9} buttons.
{MENU} {1} {3} {7} {0} buttons.
{MENU} {2} {3} {5} {6} buttons.
{MENU} {2} {3} {5} {7} buttons.
{MENU} {2} {3} {5} {8} buttons.
{MENU} {2} {3} {5} {9} buttons.
* Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
* {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
* Press the {ENTER} button to save the change.
* Press the {MENU} button twice to exit service menu.
{MENU} {8} {2} {5} {7} buttons.
Mits VZ8 chassis Menus
Option menu, Menu 1270
Service Menu, Menu 1257
Convergence Menu, Menu 1259, 4 Fine,
5 Coarse, 6 Misc.
on Apr 29, 2015 | Mitsubishi Televison & Video
Tip
Digital Noise Filter
How to remove Digital Noise Filter on Samsung LCD TV.
mas_baz_9.jpg.
1. Push menu button on remocon or on side of TV set,
2. Choose " Setup --> Plug an Play
mas_baz_10.jpg.
3. Insert pin combinations : 0-0-0-0 or your pin if you have change the pin.
4. Follow instruction until shown "Home Use" and "Store Demo".
5. Choose Home use.
Or use a simple methode by press vol up than menu for 3~5 second. It will change to home use.
on Jun 20, 2011 | Televison & Video
RCA LCD TV locked up.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Aug 12, 2012 | RCA RCR312W Remote Control
I want to download pictures from the internal memory and I attached the camera with the usb cable and it does nothing. I've tried pressing the shutter button nothing
The only way is copy pictuers from internal memory to the external memory using the camera Copy pictures or videos:
1 Press the Review button, then press the Menu button.
2 Press to highlight Copy , then press the OK button.
3 Press to highlight an option:
PICTURE or VIDEO-copies the current picture or video.
EXIT-returns to the Review menu.
ALL-copies all pictures and videos from your selected storage location to the
other location.
4 Press the OK button.
NOTE: Pictures and videos are copied, not moved. To remove pictures and videos from the original location
after copying, delete them
May 19, 2012 | GE X500 Digital Camera
I have HUMAX IR-ACE SII receiver,want 2 use nilesat
Very simply throughout the "Menu" :
01- Press Menu button on remote control.
02- Select "Installation" , input safety password - normally from
factory ( 1-2-3-4) .
03- Select "Antenne Setting" , press "OK"
04- In "Edit Satellite Data", Press "<" , then ">" , now press "Add"
05- Select Satellite , press "OK"
06- In Satellites menu select "User Define"
07- When "Do you want to rename Satellite" shows up press "OK"
08- Input (Nilesat 102) by clicking letters/figuers in sequence , then
press "OK"
09- Set Parameters as defaulted, then press "OK"
10- Now in "Edit Satellite Data", press "<" ,then select the new
sat you've just entered (Nilesat 102), and press "OK"
11- Go Back to Installation Menu by pressing "<"
12- Select "Automatic Search", press "OK"
Hope I was helpfull, best of luck
Aladin Essa = alaaalaa1900@yahoo.com
Apr 03, 2009 | Audio Players & Recorders
Wharfedale digital orb twin phone
TO REGISTER A HANDSET
[At the base]
1. Press and hold the the PAGE button on the base station for at least 3 seconds. You have 90 seconds in which to register a handset.
[At the handset]
2. Press MENU and scroll to ADVANCED SET and press MENU
3. Scroll to REGISTRATION and press MENU
4. If necessary scroll to display REGIST.BASE and press MENU
5. BASE 1 2 3 4 is displayed and the registered base number is flashing.
6. Enter the number of the base you wish to register to your handset. If you have only 1 base station, press 1. If you have 2 base stations, press 1 or 2, etc.
7. When the display shows PIN---- , enter the base pin.
8. When the handset is registered to the base it is assigned a handset number.
If you have forgotten your PIN you will need to:
Reset your ORB
1. Press MENU, scroll to ADVANCED SET and press MENU
2. Scroll to RESET UNIT and press MENU
3.CONFIRM? is displayed. Press MENU
[NOTE: Entries stored in the phonebook and new answering messages are retained. You PIN will return to the Default setting 0000]
To Set the PIN
1. Press MENU and scroll to ADVANCED SET and press MENU
2. Scroll to PIN and press MENU
3. Enter the current 4 digit master PIN and press MENU. [Default setting is 0000]
4. Enter the new PIN and press MENU
Hope this has been helpful!
Rob
Dec 28, 2008 | Uniden Cordless Phone
I forgot my pass word fro my sidekick3
yes, you can.
This tip unlocks the 3 digit security lock.
1. at the same time hold the menu button (top left) and the jump button (bottom left)
2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
4. The phone will reset and clear/unlock the security code
Known to work on the Sidekick 3
Nov 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Verge cordless phone system v581tad
I believe you have the expansion capacity of the phone all used up. The phone cannot register any more handsets until you delete the handset registered that is not in use. First check the handsets and see what handset numbers they carry. It should be #1,#2,#3,and #4 if it does not then you will have to delete the one that is missing or if it is then delete handset #5.To do this you will have to use one of the handsets registered to the base. First Press the MENU/ OK button then scroll down to ADV,SETTING then Press MENU/OK then scroll down to DEREGISTER then Press MENU/OK. Then ENTER HANDSET PIN would show, if you have not changed the pin enter 0000 if you have enter your pin member. From the next options select HANDSET and press MENU/OK from the next set of options select the handset number you want to DEREGISTER and press MENU/OK from the next option select YES then MENU/OK. Then try to reregister the new handset To do this Press the MENU/OK button then go to ADVANCE SETTING press MENU.OK scroll to REGISTER then press MENU/OK Select the base number displayed then press MENU/OK. PLEASE WAIT will appear. Then from the base press and hold the PAGE button until the handset prompts you to ENTER PIN # .Enter 0000 OR your pin number then you will see PLEASE WAIT. A tone will confirm the handset registration.
Apr 03, 2007 | Uniden Cordless Phone
T-Mobile Sidekick II Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
